Problem in startup nomount .
I have PROD database in my machine
[oracle@oracle TEST]$ df -h
Filesystem Size Used Avail Use% Mounted on
/dev/sda1 9.7G 9.0G 208M 98% /
none 1014M 0 1014M 0% /dev/shm
/dev/sda2 4.9G 263M 4.4G 6% /var
/dev/sdb1 20G 639M 19G 4% /root/test
I need to create a another database (TEST) at location /root/test/TEST
first i run dbca and configure scripts CreateDB.sql .
My first database PROD at location /u01/PROD
My ORACLE_HOME = /u01/app/oracle/product/10.2.0.1
this TEST datbase is not started and giving error as follows
SQL> connect / as sysdba;
Connected to an idle instance.
SQL>
SQL>
SQL>
SQL> startup nomount;
ORA-09925: Unable to create audit trail file
Linux Error: 2: No such file or directory
Additional information: 9925
Give me soluiton asap
you dont have the necessary file structure in place to create the audit files
He seems confused about the meaning of asap ""
permissions!!!
make sure "oracle" user has permissions on /root/test file system
also, as Devey suggested, make sure you have necessary file structure in place for all dump destinations.
Vijay Tummala
Try hard to get what you like OR you will be forced to like what you get.
originally posted by vnktummala
that make sure that oracle user has permission on /root/test file system
first u have to check the permission on root
what??
poster is trying to create the DB in /root/test so oracle should have permissions on /root/test. permissions on /root is irrelevant here.
Vijay Tummala
