Help in a simple procedure
i want to develope a pl/sql procedure that will create an empty table. below the code that i wrote but it is not working
create procedure myProc AS
declare
first_name VARCHAR(15),
last_name VARCHAR(15),
salary FLOAT(8,2),
city VARCHAR(10),
description VARCHAR(15)
EXECUTE IMMEDIATE ('create table employee_table');
why did you think it would work - that isnt a correct create table statement
Thank you sir for pointing that out. I m very new to Sql procedure can you tell/show me the correct syntax for the above code
create table
( first_name VARCHAR(15),
salary FLOAT(8,2),
city VARCHAR(10),
lucky
u didnt get me i want to know how to create empty table using sql procedure and not using sql query....
Well... your procedure has to:
1) Be able to get all data it needs -owner, table_name, column_names, column_attributes, etc - as input parameters
2) Build a proper create table statement on the fly -dynamic sql
3) Execute such an statement
 Originally Posted by mahajanakhil198
create table
salary FLOAT(8,2),
city VARCHAR(10),
what the hell is that?
salary number(8,2),
city VARCHAR(10),
or
EXECUTE IMMEDIATE '
salary number(8,2),
city VARCHAR(10),
or
EXECUTE IMMEDIATE '
salary number(8,2),
city VARCHAR(10),
Lots of ways there. You can't just give table structure that way.
