Make problem installing Oracle 10.2
I am attempting to install Oracle 10.2 on an HPUX server running 11.11 (32- bit), all goes well until 83% in to the installation during the linking phase when I get various link errors. I reran one of the makes that failed in a shell, the output is below. I'll be very greatfull for any advice.
usr/ccs/bin/make -f /ORACLE/rdbms/lib/ins_rdbms.mk ioracle ORA
chmod 755 /ORACLE/bin
- Linking Oracle
rm -f /ORACLE/rdbms/lib/oracle
cc -Wl,+s -Wl,+n +DA2.0W +DS2.0 -o /ORACLE/rdbms/lib/oracle -L/ORACLE
/rdbms/lib/ -L/ORACLE/lib/ `if /usr/bin/getconf KERNEL_BITS | grep "64" > /dev/
null ; \
then echo "-Wl,+pi,64M -Wl,+pd,L -Wl,+padtext,16M -Wl,+paddata,1M" ; \
else echo "" ; fi` -Wl,-PF,linkorderfile -Wl,+Ostaticprediction /ORACLE/
rdbms/lib/opimai.o /ORACLE/rdbms/lib/ssoraed.o /ORACLE/rdbms/lib/ttcsoi.o /ORAC
LE/rdbms/lib/defopt.o /ORACLE/lib/nautab.o /ORACLE/lib/naeet.o /ORACLE/lib/naect
.o /ORACLE/lib/naedhs.o /ORACLE/rdbms/lib/config.o -lserver10 -lodm10 -lnnet10
-lskgxp10 -lhasgen10 -lcore10 -lskgxn2 -locr10 -locrb10 -locrutl10 -lhasgen10
-lcore10 -lskgxn2 -lskgxn2 -lclient10 -lvsn10 -lcommon10 -lgeneric10 -lknl
opt `if ar tv /ORACLE/rdbms/lib/libknlopt.a | grep xsyeolap.o > /dev/null 2>&1 ;
then echo "-loraolap10" ; fi` -lclsra10 -ldbcfg10 -lslax10 -lpls10 -lplp10 -l
jox10 -lwwg `cat /ORACLE/lib/ldflags` -lnsslb10 -lncrypt10 -lnsgr10 -lnzjs1
0 -ln10 -lnnz10 -lnl10 -lnro10 -lmm -lnls10 -lcore10 -lxml10 -lunls10 `if
ar tv /ORACLE/rdbms/lib/libknlopt.a | grep "kxmnsd.o" > /dev/null 2>&1 ; then ec
ho " " ; else echo "-lordsdo10"; fi` -lctxc10 -lctx10 -lzx10 -lgx10 -lordimt10
-lsnls10 `if ar t /ORACLE/lib/libskgxp10.a | grep '^'skcsi.o > /dev/null 2>&1 ;
then echo "/opt/clic/lib/pa20_64/libclic_csi.a";fi` /ORACLE/rdbms/lib//ssoident.
o /ORACLE/lib/libocijdbc10.a `cat /ORACLE/lib/sysliblist` -lm -lcres
ld: (Warning) Can't open the fdp output file linkorderfile
1 warnings.
mv -f /ORACLE/bin/oracle /ORACLE/bin/oracleO
mv /ORACLE/rdbms/lib/oracle /ORACLE/bin/oracle
chmod 6751 /ORACLE/bin/oracle
Make: Don't know how to make ORA.
Whats the output of
whereis ld
which ld
whereis ar
which ar
whereis make
which make
nrishy.....here they are
$ whereis ld
ld: /usr/bin/ld /usr/ccs/bin/ld /usr/share/man/man1.Z/ld.1
$ which ld
/usr/bin/ld
$ whereis ar
ar: /usr/bin/ar /usr/ccs/bin/ar /usr/share/man/man1.Z/ar.1 /usr/share/man/man4.Z
/ar.4
$ which ar
/usr/bin/ar
$ whereis make
make: /usr/bin/make /usr/ccs/bin/make /usr/share/man/man1.Z/make.1
$ which make
/usr/bin/make
Hmm whats the output of
ls -ltr /usr/bin/ld
and
ls -ltr /usr/ccs/bin/ld
Try doing
export PATH=/usr/ccs/bin:${PATH}
before running the installer and try again
Hrishy
hrishy,
...oops I replied to your last reply twice, I've got the hang of it now;
The output you asked for is
$ ls -ltr /usr/bin/ld
lr-xr-xr-t 1 root sys 15 Dec 19 14:07 /usr/bin/ld -> /usr/cc
s/bin/ld
$ ls -ltr /usr/ccs/bin/ld
-r-xr-xr-x 1 bin bin 954368 Sep 17 16:12 /usr/ccs/bin/ld
- im out of the office now, back 9am(GMT) 29th Jan.
Whats the output of
file /stand/vmunix
$ cd $ORACLE_HOME/bin
$ file oracle
I am suspecting that you are installing 64 bit oracle on a 32 bit machine
$ file /stand/vmunix
/stand/vmunix: PA-RISC1.1 executable -not stripped
$ file oracle
oracle: ELF-64 executable object file - PA-RISC 2.0 (LP64)
Whats the output of
getconf KERNEL_BITS
Hrishy
Hrishy,
It's
$ getconf KERNEL_BITS
32
Am i attempting to install oracle 10g 64 bit on a 32bit O/S? The Oracle I downloaded was Oracle Database 10g Release 2 (10.2.0.1.0)
Enterprise/Standard Edition for HP-UX PA-RISC??
Nobby
