problem with procedure
SQL> ed
Wrote file afiedt.buf
1 create or replace procedure xcal_test1.missingrecords
2 is
3 clipsessionid_temp clipsession.clipsessionid%type;
4 articleno_temp mediaitem.articleno%type;
5 Cursor c2 is select cs.clipsessionid, mi.articleno
6 FROM mediaitemelectronicpage mip,
7 mediaitem mi,
8 clipsession cs,
9 clipping c,
10 media m
11 WHERE cs.clipsessionid= c.clipsessionid
12 AND c.mediaitemid= mi.mediaitemid
13 AND mi.mediaitemid= mip.mediaitemid(+)
14 AND mi.mediano= m.mediano
15 AND cs.clipsessionid in(select CLIPSESSIONID from clipsession where sessionstatusid in (9,18,2
16 and mip.SOURCEPATH is null
17 order by mi.articleno;
18 begin
19 open c2;
20 while c2%found
21 loop
22 fetch c2 into clipsessionid_temp, articleno_temp;
23 -- dbms_output.put_line('Cursor2');
24 dbms_output.put_line('select count(*) from missingarticles;');
25 End Loop;
26 dbms_output.put_line('C2');
27 while c2%Notfound
28 loop
29 fetch c2 into clipsessionid_temp, articleno_temp;
30 dbms_output.put_line('select count(*) from missingarticles;');
31 end loop;
32 Close c2;
33* End missingrecords;
SQL> /
Procedure created.
SQL> exec procedure xcal_test1.missingrecords
BEGIN procedure xcal_test1.missingrecords; END;
ORA-06550: line 1, column 7:
PLS-00103: Encountered the symbol "PROCEDURE" when expecting one of the
following:
begin case declare exit for goto if loop mod null pragma
raise return select update while with
close current delete fetch lock insert open rollback
savepoint set sql execute commit forall merge
pipe
The symbol "PROCEDURE" was ignored.
SQL>
Could anyone correct me where Iam wrong in the above code.
Iam basically trying to create a cursor and depending upon the output/result, do the two different activities!
K.Diwakar
exec xcal_test1.missingrecords
Thank you for the reply that has helped me to go to the next step!
Please clarify the same again in the code below:
create or replace procedure missingrecords
is
c_missingarticles number;
mediaitem mi,
clipsession cs,
clipping c,
media m
AND cs.clipsessionid in(select CLIPSESSIONID from clipsession where sessionstatusid in (9,18,21,23,29,33,34,35,36))
open c2;
while c2%found
loop
Dbms_output.put_line(clipsessionid_temp); -- dbms_output.put_line('Cursor2');
--dbms_output.put_line('select count(*) from missingarticles;');
End Loop;
-- dbms_output.put_line('C2');
while c2%Notfound
loop
-- dbms_output.put_line('select count(*) from missingarticles;');
dbms_output.put_line(clipsessionid_temp);
end loop;
Close c2;
End missingrecords;
Now the line in bold does not give me the value when I execute the procedure:
SQL> exec missingrecords;
-------Dont see the value of clipsessionid_temp
SQL>
Thank you very much.
K.Diwakar
Your WHILE statement has several problems.
1- You are testing for NotFound instead of testing for Found.
2- Even if you test for Found, since you have not attempted yet to Fetch a row the returned value would be NULL, not TRUE as you want it to be.
Thank You for the reply.
Now I think I should give the whole scenario.
I also suppose I need to declare a cursor for
as the outer select statement(cursor C2) executes for every value of the above select statement in bold!
Now comes my doubt:
How can you pass the value returned by one cursor to another?
And also as you have mentioned and for the two results: %found and %notfound, more calculations need to be done - I have just tried to see if the loop works!
Kindly suggest a way out for:
passing every value returned by the cursor for the statement:
to the cursor
C2
Thank you,
K.Diwakar
you didnt set serveroutput on
This has been set to the on position:
set serveroutput on
so could you please clarify on how to pass one cursor value to another please?
K.Diwakar
