Results 1 to 10 of 12
Thread: Performane problem PROD versus PREPROD
    Jun 2001
    ORACLE 9.2
    Solaris 2.8
    BLOCKS : 8k
    We have 2 databases, the production and the pre-pod.
    The pre-pod database is refreshed periodically with the data
    from prod using inport/export dumps.
    Lately, I have come across a performance problem on the production database.
    A Full scan of one particular table takes 32 minutes versus 9 minutes
    on the pre-prod , when the machine on the pre-prod is normally slower than
    the prod one.
    The prod table has more rows than the one on the pre-prod (144718411 versus 121815630).
    For me that should not account for the difference.
    I thought that maybie , I had chained rows on the production database.
    So, to prove my assumption, I ran those queries that I am listing with results both on the pre-prod
    and the prod :
    QUERY 1 :
    SQL> select a.name, b.value
    from v$statname a, v$mystat b
    where a.statistic#=b.statistic#
    and name like 'table%';
    PRE-PROD
    NAME VALUE
    table scans (short tables) 5
    table scans (long tables) 0
    table scans (rowid ranges) 0
    table scans (cache partitions) 0
    table scans (direct read) 0
    table scan rows gotten 3
    table scan blocks gotten 3
    table fetch by rowid 85
    table fetch continued row 0
    table lookup prefetch client count 0
    10 rows selected.
    Elapsed: 00:00:00.00
    PROD
    NAME VALUE
    table fetch by rowid 26
    10 rows selected.
    Elapsed: 00:00:00.04
    QUERY 2
    SQL> select count(*)
    from contrat1.fa_usage_detail
    where id_type_identifiant is not null; (One of the first columns in the definition of the table)
    PRE-PROD
    COUNT(*)
    121815630
    Elapsed: 00:09:15.54
    PROD
    COUNT(*)
    144718411
    Elapsed: 00:31:36.26
    QUERY 3
    To verify that "table fetch continued row" is still 0
    SQL>select a.name, b.value
    PRE-PROD
    NAME VALUE
    table scans (short tables) 12
    table scans (long tables) 21
    table scan rows gotten 121815633
    table scan blocks gotten 4990985
    table fetch by rowid 1268
    10 rows selected.
    Elapsed: 00:00:00.03
    PROD
    NAME VALUE
    table scans (short tables) 10
    table scans (long tables) 25
    table scan rows gotten 144718414
    table scan blocks gotten 6167092
    table fetch by rowid 1269
    10 rows selected.
    Elapsed: 00:00:00.07
    QUERY 4
    where id_catalogue is not null;
    This is the last column of the table which was added recently, and was updated.
    I wanted to see the value of "table fetch continued row" increase to show me
    the chained rows :
    PRE-PROD
    COUNT(*)
    17355117
    Elapsed: 00:09:29.09
    PROD
    COUNT(*)
    41099556
    Elapsed: 00:33:33.13
    QUERY 5
    To verify that "table fetch continued row" increased on the prod and not on the pre-prod
    PRE-PROD
    NAME VALUE
    table scans (short tables) 19
    table scans (long tables) 42
    table scan rows gotten 243631263
    table scan blocks gotten 9981967
    table fetch by rowid 2669
    10 rows selected.
    PROD
    NAME VALUE
    table scans (short tables) 15
    table scans (long tables) 50
    table scan rows gotten 289436825
    table scan blocks gotten 12334181
    table fetch by rowid 2516
    table fetch continued row 1
    10 rows selected.
    Elapsed: 00:00:00.12
    We seem to have only one chained row which could not
    account for the difference in response time.
    I would like to add that the problem is only on this table.
    All other queries on the other tables are faster in prod than in pre-prod.
    I would also add that I ran the queries several times on the prod and on the pre-prod(when they were not busy)
    with similar results.I am showing here the results of just one run.
    If anybody have any ideas about what the problem might be, what I am doing wrong in my tests, or
    what other queries I should run , You're welcome to share your ideas.
    QUERY 6
    SQL> select blocks,chain_cnt,avg_row_len,num_rows
    from dba_tables
    where owner ='CONTRAT1'
    and table_name ='FA_USAGE_DETAIL';
    PRE-PROD
    BLOCKS CHAIN_CNT AVG_ROW_LEN NUM_ROWS
    4994116 0 286 122240740
    Elapsed: 00:00:00.02
    [B]
    PROD[/B]
    6167089 0 293 144698310
    Thanks in advance.
    I guess the HW setup and configurations make much difference in response time.
    You did not tell us the server details of prod and pre-prod.
    Are your sure both init.ora parameters are same.
    Tamil
    Jun 2001
    Quote Originally Posted by tamilselvan
    Tamil
    both init.ora are the same.
    The prod has 4 pocessors and the pre-prod 2.
    what are the explain plans
    Jun 2001
    Quote Originally Posted by davey23uk
    Both of them do a full scan of the table.
    IF I go through an index, it takes a couple of seconds in both cases.
    Northampton, England
    Whats the HWM on the table in both environments?
    Assistance is Futile...
    Jun 2001
    Quote Originally Posted by waitecj
    What is the command to get the HWM?
    Assuming that both tables are analyzed:
    --Find the total number of blocks allocated to the segment (Thus the HWM)
    SELECT BLOCKS
    FROM   DBA_SEGMENTS
    WHERE  SEGMENT_NAME = your_table;
    -- To find the number of blocks that are empty (how many blocks your are reading during a FTS for no reason)
    SELECT EMPTY_BLOCKS
    FROM   DBA_TABLES
    WHERE  ]TABLE_NAME = your_table;
    Someone else is bound to come up with simpler apporaches for this (possibly using DBMS_SPACE or something), but this will work just fine.
    Jun 2006
    Turn on tracing: and run tkprof against the trace output after running the two querries).
    "alter session set sql_trace=true "
    What is the o/s reporting for I/O stats during each querry?
    Dec 2002
    Bangalore ( India )
    check if preprod is doing FTS parallely.. on the other hand in prod serially..
    Abhay
    funky...
