Thread: DB Installation problem
    Jun 2004
    Ludhiana (Pb.) INDIA
    Question DB Installation problem
    I'm not able to install Oracle 8i (8.1.7)for WinNT, server on my IBM 8434 NZA machine. I'm using Win2K, with Service pack 4 installed. The setup doesn't start at all. Maybe I'm having some problem running Java on this machine. Setup runs and installs perfectly on older machines with same configuration. Any idea.
    Vikas Verma
    ___________
    It is the mark of an educated mind to be able to entertain a thought without accepting it.
    __________
    Aristotle
    Pentium 4? - STFW
    Jun 2004
    P4 2.53GHz, 256MB RAM. the problem is with ThinkCentre only. it's running on other machines.
    Vikas Verma
    ___________
    __________
    Aristotle
    Search the web for Pentium 4 bug - which you should have done before you even posted here
    Satge ur CD, remane file symjit.dll file, this file is prventing Universal Installer to come UP, once you remane this file, you can continue with your installation.
    Jun 2004
    thnx dear
    Vikas Verma
    ___________
    __________
    Aristotle
