Results 1 to 10 of 13
Thread: Strange Problem
    Jul 2003
    Strange Problem
    I have two databases d1 and d2 on a server. I am able to connect to d1 and not d2 (from the client). I am getting TNS: Listener not found error. My TNSNAMES.ORA file is okay, I've made the right entry. I am able to ping the server (obviously becoz I can connect to d1).
    I am able to however connect from the server end to both d1 and d2.
    Could someone solve this issue for me please...
    Vipassana
    Jul 2001
    Slovenia
    Do you have listener defined on server for both databases?
    Check listener.ora or issue lsnrctl services?
    Toma┼ż
    "A common mistake that people make when trying to design something completely
    foolproof is to underestimate the ingenuity of complete fools" - Douglas Adams
    Jul 2003
    I don't think I have multiple Listeners, there is only one. I'll check it anyway and confirm on that.
    Saskatoon, SK, Canada
    If you had made any changes on the listener after starting the listener, then you would have to reload it to get the changes take effect. In the mean time, can you do a tnsping using the tnsname of the d2 and let us know the results. It may me a typo or somthing for the d2 configuration that doesn't let you connect. Also please let us know the error tooo.
    Mar 2002
    Mesa, Arizona
    What does "lsnrctl status" return?
    "I do not fear computers. I fear the lack of them." Isaac Asimov
    Oracle Scirpts DBA's need
    Jul 2003
    I will get back with the specifics. But I must tell you that d2 is a repository database (created for oms). Would that make any difference?
    Jul 2003
    Okay Guys, here are the details:
    LSNTCTL STATUS
    :\ora9idb\bin>lsnrctl status
    LSNRCTL for 32-bit Windows: Version 9.2.0.1.0 - Production on 30-JUL-2003 16:37:
    33
    Copyright (c) 1991, 2002, Oracle Corporation. All rights reserved.
    Connecting to (DESCRIPTION=(ADDRESS=(PROTOCOL=IPC)(KEY=EXTPROC1)))
    STATUS of the LISTENER
    Alias LISTENER
    Version TNSLSNR for 32-bit Windows: Version 9.2.0.1.0 - Produc
    tion
    Start Date 30-JUL-2003 15:22:51
    Uptime 0 days 1 hr. 14 min. 45 sec
    Trace Level off
    Security OFF
    SNMP OFF
    Listener Parameter File f:\ora9idb\network\admin\listener.ora
    Listener Log File f:\ora9idb\network\log\listener.log
    Listening Endpoints Summary...
    (DESCRIPTION=(ADDRESS=(PROTOCOL=ipc)(PIPENAME=\\.\pipe\EXTPROC1ipc)))
    (DESCRIPTION=(ADDRESS=(PROTOCOL=tcp)(HOST=incq246bb.idc.oracle.com)(PORT=1521)
    (DESCRIPTION=(ADDRESS=(PROTOCOL=tcp)(HOST=incq246bb.idc.oracle.com)(PORT=8080)
    )(Presentation=HTTP)(Session=RAW))
    (DESCRIPTION=(ADDRESS=(PROTOCOL=tcp)(HOST=incq246bb.idc.oracle.com)(PORT=2100)
    )(Presentation=FTP)(Session=RAW))
    Services Summary...
    Service "ODEMEA" has 2 instance(s).
    Instance "ODEMEA", status UNKNOWN, has 1 handler(s) for this service...
    Instance "ODEMEA", status READY, has 1 handler(s) for this service...
    Service "ODEMEAXDB" has 1 instance(s).
    Service "OEMREP.idc.oracle.com" has 2 instance(s).
    Instance "OEMREP", status UNKNOWN, has 1 handler(s) for this service...
    Instance "OEMREP", status READY, has 1 handler(s) for this service...
    Service "OEMREPXDB.idc.oracle.com" has 1 instance(s).
    Service "PLSExtProc" has 1 instance(s).
    Instance "PLSExtProc", status UNKNOWN, has 1 handler(s) for this service...
    Service "oem_repo" has 2 instance(s).
    Instance "oemrepo", status UNKNOWN, has 1 handler(s) for this service...
    Instance "oemrepo", status READY, has 1 handler(s) for this service...
    Service "oemrepoXDB" has 1 instance(s).
    The command completed successfully
    TNSPING OUTPUT
    C:\>tnsping oemrep
    TNS Ping Utility for 32-bit Windows: Version 9.2.0.1.0 - Production on 30-JUL-20
    03 16:57:59
    Copyright (c) 1997 Oracle Corporation. All rights reserved.
    Used parameter files:
    Used TNSNAMES adapter to resolve the alias
    Attempting to contact (DESCRIPTION = (ADDRESS_LIST = (ADDRESS = (PROTOCOL = TCP)
    (HOST = incq246bb)(PORT = 1521))) (CONNECT_DATA = (SERVICE_NAME = oemrep)))
    OK (40 msec)
    ERROR MESSAGE
    ERROR:
    ORA-12514: TNS:listener could not resolve SERVICE_NAME given in the connect descriptor
    OEMREP is the one I am not able to connect. This is a Repository OMS Database. I can connect using SYSTEM user from the Server, but not from the client. However, from the client, I can connect to OMS using SYSMAN on OEMREP. It falis when I connect through SQL PLUS using SYSTEM. Could someone please help.
    Sorry for lot of details in this post.
    Feb 2003
    London
    did you try tnsping from the client server. Your error message seems to look like there may be something missing in your tnsnames.ora file on the client.
    Jan 2003
    Hull, UK
    In your tnsnames.ora file, try to give IP ADDRESS instead of machinename.
    HTH
    Srini
    New Delhi, INDIA
    Try changing SERVICE_NAME to SID in your tnsnames.ora file for OEMREP
    Amar
    Amar's Blog  Get Firefox!
