ORA-00972 and other problems with OEM 2.2
Hi Guys,
My table Reorg job (Fixing Chained rows) in OEM (2.2.0.0.0) fails if the table length is more than 24 CHARS. This is because, it suffixes '$$TEMP' to the table name while creating a temporary table in which it inserts chained rows before deleting from the original table.
The workaround is that every time, I need to change the table name and reduce it to <= 24 CHARS in the Reorg script.
In OEM 2.2, if your table has Function based index (FBI) then also, its a problem. First you need to drop the FBI and then reorg that table. Another problem is that if the table has LONG/LOB column in it, you cannot do Reorg on that table.
Has anyone faced these problems and is there any direct fix for those?
Thanks in Adv.
To handle yourself, use your head. To handle others, use your heart
Hi all,
I guess nobody has got these problems. Am I correct?
Hi Guys,
I guess, nobody uses OEM for reorganizing tables and fixing chained rows here. Am I correct?
Originally posted by samdba
Am I correct?
Might be
funky...
