Export..
How to export of a user 0f 8.1.5 db into 9.0.1 db ?
Can anyone give the steps in detail ?
Thnx in Adv.
Prasad
1)Just use the export utility of 8.0.5 to make an export
2)Import the above export file into 9.02 using the 9.02 import utility ..thats it..
Hrishy
8.0.5 should be 8.1.5 and 9.02 should be 9.0.1
Amar
I am sorry amar is right ..
1)Just use the export utility of 8.1.5 db
2)Import the above export file into 9.0.1 db using the import utility of 9.0.1 db
thanks for spotting that amar..i guess ia m too drunk today ;-D
Hrishy
