Thread: Schedule Startup and Shutdown Oracle816 on Winodws NT Using AT Command Doesn't Work
    Mar 2002
    Hi Guys,
    I am trying to use Windows NT's AT command to schedule the database shutdown and startup process. But it doesn't work. The following are part of my scripts:
    (1) shutdown.sql
    connect internal
    shutdown immediate
    exit
    (2) shutdown.cmd
    e:\oracle\ora81\bin\svrmgrl.exe @shutdown.sql
    (3) AT command
    at 23:00 / every:M,T,W,Th,F,S,Su shutdown.cmd
    When I execute shutdown.cmd on DOS prompt, it works. But when the command is scheduled using AT command, it never works.
    I will appreciate if any one can help me.
    Sep 2001
    NJ, USA
    Why need so long procedure for startup/shutdownd db on nt.
    Much easy use oradim utility for start/stop oracle services
    (listener and instance).
    http://download-east.oracle.com/otnd...h2.htm#1181056
    Mar 2002
    Shestakov,
    Thanks for your answer. I will try the oradim utility.
    But I still want to know the reason why AT command can not work.
    Czechia
    * Write absolute paths to commands, e.g.:
    (2) shutdown.cmd
    e:\oracle\ora81\bin\svrmgrl.exe @e:\scripts\shutdown.sql
    (3) AT command
    at 23:00 / every:M,T,W,Th,F,S,Su e:\scripts\shutdown.cmd
    * If it still doesn't work send output to a log file and check it:
    (3) AT command
    at 23:00 / every:M,T,W,Th,F,S,Su e:\scripts\shutdown.cmd > e:\scripts\log.txt
    * Try to set ORACLE_SID:
    (2) shutdown.cmd
    set ORACLE_SID=orcl
    Ales
    The whole difference between a little boy and an adult man is the price of toys
