I am trying to create some external tables and I get strange results.
I have a flat file as follows
20020821 00:00:00;Sop Ges Arpa;1;4;1;0;0;
20020821 00:00:00;Sop Ges Arpa Rech;0;3;1;0;0;
20020821 00:00:00;Sop Ges Arpa Res;0;20;3;0;7;
20020821 00:00:00;Sop Ges Arpa Tra;5;0;5;0;0;
20020821 00:00:00;Sop Ges Portabilidad;9;1;9;0;0;
created external table as follows
create table
colas_caup
(fecha date,
cola VARCHAR2(45),
ABIERTAS number,
CERRADAS number,
PENDIENTES number,
RECHAZADAS number,
RESUELTAS number)
organization external
(type oracle_loader
default directory tablas_externas
access parameters
(records delimited by newline
fields terminated by ';'
missing field values are null
(fecha char date_format date mask 'YYYYMMDD HH24:MI:SS',
cola,
ABIERTAS,
CERRADAS,
PENDIENTES,
RECHAZADAS,
RESUELTAS))
location('colas.dat'))
reject limit unlimited;
the problem is when I query I get only the first row back with no errors at all in the log!
if then I change the flat file into
I get 0 rows and error in log stating:
error processing column RESUELTAS in row 1 for datafile /tmp/colas.dat
ORA-01722: invalid number
I then again edit the flat file so it shows now
query the table and get the row back with no errors
I cant see what the heck is going on
Anyone tried external tables :?
Just check if there are any invisible characters like 'TAB' at the end of last character in flat file.
Sameer
nop, there is no tabs
in fact this flat file is one of many that feed datamart loading processes with sql loader which loads with no problems at all
Just a suggestion..
How about taking partial file for loading..
If the file has only 1 rec and then it shows properly, then we can give a try taking records in batches... Might be one of the one of the record in the flat file has a junk character.
may be initially 100 then next 100
I understand file may have millions of records.. You must have shown us a sample records.. but we can give a try....
Sameer
well the funny thing is querying following flat file
I get 20020821 00:00:00;Sop Ges Arpa;1;4;1;0;0; back as result
if i change the file to
I get 20020821 00:00:00;Sop Ges Arpa Rech;0;3;1;0;0; back as result so the data are not bad, the problem is it only reads the first row
and if I have 1 million rows obviously I am not gonna split it into 1 million files
Ofcourse not.. But I have tried the same code at my home, I just copy-pasted everything and it worked without a single error
I am using WinXP, O9i R2. Heres the output.. There must be something wrong with the flatfile only.. No syntax error.. nothing.. Following is the spooled output..
SQL> CREATE OR REPLACE DIRECTORY tablas_externas AS 'c:\oracle\etl_file';
Directory created.
SQL> CREATE TABLE
2 colas_caup
3 (fecha DATE,
4 cola VARCHAR2(45),
5 ABIERTAS NUMBER,
6 CERRADAS NUMBER,
7 PENDIENTES NUMBER,
8 RECHAZADAS NUMBER,
9 RESUELTAS NUMBER)
10 ORGANIZATION EXTERNAL
11 (TYPE oracle_loader
12 DEFAULT DIRECTORY tablas_externas
13 ACCESS PARAMETERS
14 (RECORDS DELIMITED BY NEWLINE
15 FIELDS TERMINATED BY ';'
16 MISSING FIELD VALUES ARE NULL
17 (fecha CHAR date_format DATE MASK 'YYYYMMDD HH24:MI:SS',
18 cola,
19 ABIERTAS,
20 CERRADAS,
21 PENDIENTES,
22 RECHAZADAS,
23 RESUELTAS))
24 LOCATION('colas.dat'))
25 REJECT LIMIT UNLIMITED;
Table created.
SQL>
SQL> SELECT * FROM colas_caup;
FECHA COLA ABIERTAS CERRADAS PENDIENTES RECHAZADAS RESUELTAS
21-AUG-02 Sop Ges Arpa 1 4 1 0 0
21-AUG-02 Sop Ges Arpa Rech 0 3 1 0 0
21-AUG-02 Sop Ges Arpa Res 0 20 3 0 7
21-AUG-02 Sop Ges Arpa Tra 5 0 5 0 0
21-AUG-02 Sop Ges Portabilidad 9 1 9 0 0
5 rows selected.
I will be glad if u reply back after solving the problem
Sameer
hmmm this is gettng my nerves, I just cut and pasted in another server and it works
bummer :-(
You probably have problems with 'newline'. It can be CHR(13) or CHR(10)||CHR(13) together. On of the above is giving you problems.
I am not sure, the dat is generated by sql*plus spool
I think that sqlplus spool adds blanks en every result row until linesize.
