Thread: export problem
    Apr 2002
    I tried to export a table
    i got thefollowing error:
    EXP 00056 : oracle error 01033 encountered
    ORA-01033:Oracle initialization or schutdown in progress.
    Then it asked me to enter the username
    please help
    deepa
    Feb 2000
    Singapore
    Is you database up?
    Try a connection from sqlplus.
    Sanjay
    Apr 2002
    yes it is up.i can connect from sqlplus.
    when i do a export as internal/oracle login, then it gives
    ora-01219 error:database not open : queries allowed on fixed tables/views only
    Feb 2002
    Check your ORACLE_SID.
    Manifest plainness,
    embrace simplicity,
    reduce selfishness,
    have few desires. LAO TZU
    Sep 2000
    shutdown the database and start it again and then take export.
    hope this will work.
    Shailendra
    Mar 2002
    Check your tnsnames.ora file through which you connect to SQL*Plus.
    Your database(through which you are trying to take a export is at mount phase) is down. Try issuing a command
    'alter database open' if it fails then take neccessary action.
    (it will fail only if recovery is required).
    Vijay.
    Say No To Plastics
