Thread: Problem installing Oracle 8.1.5
    Hi gurus,
    I am trying to install Oracle 8.1.5 (32 bit) on an E250 development server running Solaris 8. I have done all preinstallation tasks: creating the user,group and directories, changing ownership, setting kernel parameters, oracle user environment variables (ORACLE_HOME, LD_LIBRARY_PATH, PATH, ORACLE_SID). However I am getting the following error when I run the Installer:
    Error in invoking target ntcontab.o of makefile /export/home/oracle/oraHome1/network/lib/ins_net_client.mk
    Hope someone can help me out here.
    Many thanks in advance!
    Cheers,
    Ben
    [Edited by bcheong on 05-22-2002 at 07:43 AM]
    Change the oracle user's .profile to somthing like this.Remember the PATH should be in the same order as I have specified here.i.e. usr/ccs/bin should come before /usr/bin and run the installer again.Let me know if this works
    ORACLE_BASE=/u01/app/oracle
    ORACLE_HOME=/u01/app/oracle/product/8.1.7
    export ORACLE_BASE ORACLE_HOME
    LIBPATH=$ORACLE_HOME/lib
    export LIBPATH
    LD_LIBRARY_PATH=$ORACLE_HOME/lib:$ORACLE_HOME/network/lib:/usr/lib
    export LD_LIBRARY_PATH
    ORACLE_SID=PEGD
    export ORACLE_SID
    PATH=$ORACLE_HOME/bin:/usr/ccs/bin:/usr/bin:/etc:/bin:/usr/sbin:/usr/ucb:/usr/bin/X11:/sbin:/usr/local/bin:.
    export PATH
    Jun 2001
    Run the make file.
    Command
    make -f install
    You might get linking error after running make file.
    Do this: in usr/lib - softlink that file /lib
    Try to do this.
    Akash
    Akash
    Talking
    Hi guys,
    Thanks for your replies. I've managed to solve the problem. It was embarassingly easy in the end.
    The profile had all the required environment variables defined. However, after looking at the make.log, i noticed that it was complaining that it couldn't execute /usr/ccs/bin/cpp. The reason? The file wasn't there! After just copying all the /usr/css/bin files over from another server, the installer completed the installation without a hitch.
    Now I'm going to look for the Sysadmin who installed the OS and give him evil looks. =)
    Thanks again guys.
    Cheers!
    Ben
