Thread: Problem with svrmgrl
    Mar 2002
    Exclamation
    I have a problem with server manager in a 8i database , i'm trying to execute svrmgrl in Aix operating system but i can't and i can´t start de database.
    please if somebody knows what i can do to load the svrmgrl, tell me .
    Mar 2002
    Mesa, Arizona
    If the Oracle software is installed, try using sqlplus instead of svrmgrl. svrmgrl functionality is being taken over by sqlplus.
    "I do not fear computers. I fear the lack of them." Isaac Asimov
    Oracle Scirpts DBA's need
    Charlotte, USA
    What is the error you are getting...?.while executing svrmgrl.
    check file under $ORACLE_HOME/bin/svrmgrl...mod 755?.
    Thanigaivasan.
    Mar 2002
    I couldn't execute sqlplus and when i try to execute svrmgrl , i have the following errors:
    0509-136 cannot load program svrmgrl because of following errors:
    0509-130 symbol resolution failed for svrmgrl because:
    0509-136 symbol pw_post (number-259) is not exported from dependent module /aix
    Charlotte, USA
    Hi here is the solution from metalink for the similar problem on the same platform.....
    Subject: Re : cannot start svrmgrl
    It means your application needs post-wait kernel driver.
    FTP the file 'pw-syscall' and FTP executable load.exe to client machine.
    Load it to the OS kernel and your application will run fine.
    - Jaikishan
    Oracle Support Services
    Hi Jaikishan;
    It works. I think you very much.
    Thanigaivasan
