When I execute this Query, its pretty fast. It takes just a second.
SELECT
count(*)
FROM TSW_CODES CD1,
TSW_CODES CD2,
TSW_CODES CD3,
TSW_CODES CD4,
TSW_CODES CD5,
TSW_CODES CD6,
TSW_CODES CD7,
TSW_PERSONNEL EMP,
EAM_COMPONENTS CMP,
EWM_WO_AUDITS WOA
WHERE ( CD1.CODE_ID (+) = WOA.WO_STATUS_ID ) and
( CD2.CODE_ID (+) = WOA.ACTION_ID ) and
( CD3.CODE_ID (+) = WOA.CATEGORY_ID ) and
( CD4.CODE_ID (+) = WOA.AREA_ID ) and
( CD5.CODE_ID (+) = WOA.ASSET_STATUS_ID ) and
( CD6.CODE_ID (+) = WOA.PRIORITY_ID ) and
( CD7.CODE_ID (+) = WOA.SHUTDOWN_ID ) and
( EMP.EMP_NO = WOA.EMP_NO ) and
( CMP.SERIAL_ID (+) = WOA.COMPONENT_SERIAL_ID) and
WOA.WORK_ORDER_NO = '02-000695-000'
ORDER BY WOA.DATE_TIME DESC ;
But the same Command if I choose columns instead of count(*), it takes 5-6 minutes. Heres the SQL:
SELECT
CD1.USER_CODE WO_STATUS_CODE,
CD2.USER_CODE ACTION_CODE,
CD3.USER_CODE CATEGORY_CODE ,
CD4.USER_CODE AREA_CODE,
CD5.USER_CODE ASSET_STATUS_CODE ,
CD6.USER_CODE WO_PRIORITY_CODE,
CD7.USER_CODE SHUTDOWN_CODE
FROM TSW_CODES CD1,
TSW_CODES CD2,
TSW_CODES CD3,
TSW_CODES CD4,
TSW_CODES CD5,
TSW_CODES CD6,
TSW_CODES CD7,
TSW_PERSONNEL EMP,
EAM_COMPONENTS CMP,
EWM_WO_AUDITS WOA
I checked for Chained Rows. No chained rows. I checked for block fragments. No block fragments. What could be the problem. Please advise as it is very urgent for the next release we have here.
Did you check explain plan?
If you check it you will see that in first case you access only index blocks in second case you access index & data blocks to return result.
[Edited by kgb on 04-08-2002 at 06:33 AM]
Best wishes!
Dmitri
Okay. But how does this help me now? I even re-built all the indexes. Nothing seems to help. How to trouble shoot this problem.
Another thing: The same query performs very fast on another server with similar data. Infact, the other database fetches more rows than this one. Its all very confusing. I see the same indexes created on the tables on both the databases. Please help.
[Edited by dbafreak on 04-08-2002 at 06:39 AM]
Originally posted by pando
do you run it in local?
I am running this from the client. From SQL * PLUS.
Does your servers hace the same configurations?
Did you try to review indexes, I mean WOA.WORK_ORDER_NO = '02-000695-000' looks like a number, you could decrease index size around in 3,5 times, if you use number instead of char.
Best wishes!
Dmitri
how about try run it in local with both query, count(*) and columns and compare
Okay. Let me try that. Meanwhile here's what EXPLAIN PLAN outputted into the PLAN_TABLE:
ID PARENT_ID OPERATION SUBSTR(OBJECT_NAME,1,25)
0 SELECT STATEMENT
1 0 NESTED LOOPS OUTER
2 1 NESTED LOOPS OUTER
3 2 NESTED LOOPS OUTER
4 3 NESTED LOOPS OUTER
5 4 NESTED LOOPS OUTER
6 5 NESTED LOOPS OUTER
7 6 NESTED LOOPS OUTER
8 7 NESTED LOOPS
9 8 NESTED LOOPS OUTER
10 9 TABLE ACCESS BY INDEX ROWID EWM_WO_AUDITS
11 10 INDEX RANGE SCAN DESCENDING EWM_CON_WOU_PK
12 9 TABLE ACCESS BY INDEX ROWID TSW_CODES
13 12 INDEX UNIQUE SCAN TSW_CON_COD_PK
14 8 TABLE ACCESS BY INDEX ROWID TSW_PERSONNEL
15 14 INDEX UNIQUE SCAN TSW_CON_EMP_PK
16 7 TABLE ACCESS BY INDEX ROWID TSW_CODES
17 16 INDEX UNIQUE SCAN TSW_CON_COD_PK
18 6 TABLE ACCESS BY INDEX ROWID TSW_CODES
19 18 INDEX UNIQUE SCAN TSW_CON_COD_PK
20 5 TABLE ACCESS BY INDEX ROWID EAM_COMPONENTS
21 20 INDEX UNIQUE SCAN EAM_CON_CMP_PK
22 4 TABLE ACCESS BY INDEX ROWID TSW_CODES
23 22 INDEX UNIQUE SCAN TSW_CON_COD_PK
24 3 TABLE ACCESS BY INDEX ROWID TSW_CODES
25 24 INDEX UNIQUE SCAN TSW_CON_COD_PK
26 2 TABLE ACCESS BY INDEX ROWID TSW_CODES
27 26 INDEX UNIQUE SCAN TSW_CON_COD_PK
28 1 TABLE ACCESS BY INDEX ROWID TSW_CODES
29 28 INDEX UNIQUE SCAN TSW_CON_COD_PK
Pando: I tried from the Server. Same problem. COunt takes a second and colums fetch takes about 4-5 minutes.
It is supposed to be a VARCHAR unfortunately.
