Thread: problems with Rollback Segments in 9i
    Dec 2001
    Brazil
    Angry
    I create a tablespace for storing data from my tables:
    create tablespace clients01 datafile 'c:\tbs\clients01.dbf' size 10m;
    then I need to create a rollback segment for this tablespace:
    create rollback segment rbs_seg01 tablespace clients01 storage (initial 1m next 1m minextents 3 optimal 4m);
    then sql*plus says "it's not possible to create a rollback
    segment in this tablespace... " error ORA-25151.
    I'm using oracle 9i personal edition ... in 8i I do it perfectly.
    Can someone tell me what's the problem please? Thanks anyway.
    greenwich.ct.us
    9i doesn't use Rollback segments. See http://download-west.oracle.com/otnd...pace.htm#10700 for details.
    Dec 2001
    Brazil
    Thank you very much for your answer.
    But I still have problems.
    I created a tablespace called clients01 (see above).
    then I created a table, code for my table:
    CREATE TABLE CLIENT (
    code NUMBER,
    name VARCHAR2(15),
    adress VARCHAR2(30))
    TABLESPACE clients01;
    then when I try to insert a row:
    INSERT INTO CLIENT VALUES (001, 'BLAH', 'BLEH');
    sql*plus says "it's not possible to use the system rollback
    segment for tablespace 'clients01' non-system. the error is
    ORA-01552.
    what am I doing wrong?
    thank you.
    F.
    Jun 2001
    Helsinki. Finland
    1. Run
    create UNDO TABLESPACE clients01 datafile 'c:\tbs\clients01.dbf' size 10m;
    2. Bounce the instance with setting in INIT.ORA
    UNDO_MANAGEMENT = auto
    UNDO_TABLESPACE = clients01
    COMPATIBLE = 9.0.0
    3. Now create the table and so on...
