Thread: Trigger body
    Hello : I have to modify a trigger and I want to pull that from the source. I have always pulle dup procedures from user_source and have modified it and saved it and compiled. Similarly how do I do it with triggers? If I use user_triggers what should the value of long be ? so I can see the entire text.
    Thanks, ST
    UK
    Use trigger_body from sys.dba_triggers. It's a long column, so you may have to do "set long xxxxx" in sql*plus to see all of it.
    Why don't you use something like TOAD? I think you could done load a basic version for free.
    J.T.
