I would like to know why the cursor is failling after it select couple of records.
CREATE OR REPLACE PROCEDURE sp_test_cursor( i_input in number)
IS
v_msisdn varchar2(11);
CURSOR cur_npa_split IS SELECT lmsisdn FROM customer;
-- Open
OPEN cur_npa_split;
LOOP
FETCH cur_npa_split
INTO v_msisdn;
EXIT WHEN cur_npa_split%NOTFOUND;
DBMS_OUTPUT.PUT_LINE('MSISDN='||v_msisdn);
END LOOP;
-- Close
CLOSE cur_npa_split;
COMMIT;
EXCEPTION
WHEN DUP_VAL_ON_INDEX THEN
RAISE_APPLICATION_ERROR(-20518,
'Duplicate Value on Index...');
WHEN NO_DATA_FOUND THEN
RAISE_APPLICATION_ERROR(-20519,
'No_Data_Found Occur...');
WHEN TOO_MANY_ROWS THEN
RAISE_APPLICATION_ERROR(-20520,
'Select Too Many Rows...');
WHEN OTHERS THEN
RAISE_APPLICATION_ERROR(-20521,
'UN-NONE ERROR Occur...');
END sp_cnot_sync_cursor;
ERROR:
MSISDN=6784311664
BEGIN sp_cnot_sync_cursor(1); END;
ORA-20521: UN-NONE ERROR Occur...
ORA-06512: at "SYNCMIN.SP_CNOT_SYNC_CURSOR", line 41
ORA-06512: at line 1
Chandra
