    Berlin
    I tried to create a tablespace. Unfortunaley, I did not have enough space so I received this error below
    create tablespace DATA_2001
    ORA-19502: write error on file
    "/u01/ora01/mydata_2001.dbf", blockno 385601
    (blocksize=4096)
    ORA-27063: skgfospo: number of bytes read/written is incorrect
    IBM AIX RISC System/6000 Error: 28: No space left on device
    Additional information: -1
    Additional information: 262144
    "/u01/ora01/mydata_2001.dbf", blockno 386177
    (blocksize=4096)
    Now I have a lot of space. So Idecided to go back to create the same tablespace again. But now I am getting the message that the file already exists.
    ORA-01119: error in creating database file
    '/u01/ora01/mydata_2001.dbf'
    ORA-27038: skgfrcre: file exists
    Any help will be apprecitaed.
    OS/AIX
    DATABASE VERSION:8.1.5.0.0
    Cambridge, MA (Boston)
    Did you delete the file from the aborted attempt to create the tablespace? oracle will not remove the leftovers. in general, oracle does not manage files from the OS when you do any database drops, deletes or renames.
    d.
    Berlin
    okay. So I'm thinking that I have to delete the file from the OS level. Can you give me the command to do this in unix assuming the datafile name is "/u01/ora01/mydata_2001.dbf''.
    I'm new to unix so I want to make sure that I am deleting the right stuff. I will aprreciate an example.
    I'm running AIX.
    Apr 2000
    Edison, NJ
    Command to delete a file in UNIX: rm (file_name)
    example: rm /u01/ora01/mydata_2001.dbf
    ahh, did not realize you're a newbie to unix, too. the command is "rm" (obvious, right?). to be really sure, use the -i flag to confirm the name. e.g.
    rm -i /u01/ora01/mydata_2001.dbf
    git yerself a good unix starter book soon. it will make your life easier.
    d.
    Berlin
    thanks
