SQL HELP
Thread: SQL HELP
    Nov 1999
    select count(orrfnbr),sum(orprtot) ,count(shipto.strfnbr) from
    select count(orrfnbr) ,sum(orprtot) from
    Select distinct orders.orrfnbr, orders.orprtot
    FROM
    ordpaymthd , orders
    WHERE
    ordpaymthd.omornbr = orders.orrfnbr
    AND ordpaymthd.ompaymthd !='FR'
    AND ordpaymthd.ompaymthd !='SW'
    AND orders.orstat='C'
    and trunc(shipto.sttrkdate) = '01-JAN-01'
    AND orders.orrfnbr = shipto.stornbr))
    I need to make this work , selecting distinct of orrfnbr ,orprtot from ordpaymthd , orders
    and then calculating count and sum for the respectively and then to check out from SHIPTO
    table how many items for that .
    try this
    select b.cnt count,b.sm sum from
    select count(a.orrfnbr) cnt,sum(a.orprtot) sm from
    FROM
    ordpaymthd , orders
    WHERE
    AND orders.orrfnbr = shipto.stornbr) a ) b
    Try this. You have to select shipto.strfnbr from one of the subqueries or another table in order to do a count on it. If you add it to one of your subqueries just add the appropriate letter in front of it. You don't have to do the count and the sum in the main query because you already did it in the subquery.
    Nov 1999
    This is not running , I could do for 2 tables but the problem is when I add the 3rd table
    SHIPTO . Please let me know what is the complete SQL as this is not running
    Nov 1999
    Thanks done
