Thread: how does 11.5.3 work exactly?
    I have installed oracle applications 11.5.3 on sun solaris 2.6
    I have to start post install steps.
    can somebody tell me how jinitiator and digital certificate works? I mean the concept?
    Do i have to create digital certificate on my sun server,run jinitiator and then make a copy onto a client m/c ( 95 or 98) and then access the sun server from that client?
    thanks in advance
    before you worry too much about certificates
    make sure that you can access the apps from the server that you installed the apps on.
    is it giving you any errors related to certificates or digital signatures?
    if not, dont worry since you seem to be installing for demo / testing purposes
    Also please click below for metalink doc explaining the process for setting up certificate and repackaging jinitiator
    http://dbasupport.com/oracle/resourc..._Applications/
    uday
    [Edited by uday on 03-27-2001 at 01:16 PM]
