I have a simple mathematical question that I'm fighting with.
Can any one help?
In terms of percentage, what does this number mean
.008333333
I ran a query and I'm supposed to get less than 4%. But I received
this output .008333333. So I'm wondering if its more than 4%. How do
determine the percentage based on a value like this
Exactly what is the calculation you are doing?
It looks to me like it's probably around 8/10's of 1%
_________________________
Joe Ramsey
Senior Database Administrator
dbaDirect, Inc.
(877)687-3227
SQL> select d.value/m.value
2 from v$sysstat d, v$sysstat m
3 where d.name = 'sorts (disk)'
4 and m.name = 'sorts (memory)';
D.VALUE/M.VALUE
.00833333
o.K now it makes sense. Modify your query to be as follows
select (d.value/m.value) *100
This would give you .8% < 4%
I'm sure the answer below means 7% right?
SQL> select (d.value/m.value) *100
(D.VALUE/M.VALUE)*100
.78125
.78125
it should be: .078125 ===> 7.8%
No 0.78%, (d.value/m.value) *100 is the percentage.
select (d.value/m.value) *100 "Percentage"
ok. so based on this out put, what would you say the percentage is?
.78125
It would be .78%.
50% of 100 would be (50/100) * 100 = 50
10% of 40 would be (10/100) * 40 = .40
In short
(value/total_value) * 100 = percentage
Hope this would help you to strainghten your math
This thread is becoming terribly scary
Joe Ramsey
dbaDirect, Inc.
(877)687-3227
