backup and recover using tar
Thread: backup and recover using tar
    Jan 2000
    san jose
    hi,
    my sun box and a tape driver attached to it.
    how should i backup offline files to it?
    what's my possible choice?
    tar, cpio?
    if so , give me an example.
    I guess it is a unix question instead of oracle question.
    Saskatoon, SK, Canada
    Since I use RMAN over backup, I don't know about making the tape drive interface. But would suggest using "dump" over "tar".
    Depending on the size of your DB you have many choices. RMAN can be a good solution however it requires another instance to be the DB for the backups.
    If your DB isn't too big running nightly crons to export the DB is a great thing. I have 3 smaller DBs and have restored tables due to user mistakes very quickly because I had nightly exports. The cron looks like:
    #!/bin/sh
    ## This is a nightly export of the users of an Oracle database
    ORACLE_SID=fred
    export ORACLE_SID
    # Get the environment
    . /u00/oracle/app/oracle/product/7.3.4/.profile
    cd /u02/exports
    exp sys/password file=fred.dmp.`date +%y.%m.%d` log=fred.log.`date +%y.%m.%d` full=y
    Its simple and to the point. Don't forget to %chmod 700 because the password is in the file- you could set it up to run without a password.
    As far as the full backups are concerned, there are several great scripts out on the net that will perform HOT or COLD backups. Try this URL to start. The scripts found work almost direct out of the box:
    BACKUP CENTRAL:
    [url]http://www.backupcentral.com/toc-free-backup-software.html[/url]
    Cheers,
    Roger
