Results 1 to 7 of 7
    One of our customer wrote when I asked him why he had created a combination index on the columns that already had individual indexes and he wrote...
    index 1 - res_entity_type
    index 2 - res_level
    index 3 - res_entity_type, res_level
    index4 - res_status, res_int_ext8, res_entity_type
    What I am concerned about is index 3 !
    Part1:
    In our mwebres table, the res_entity_type column values are very skewed. We have 72 rows where
    res_entity_type = 1 and 32,456 rows where res_entity_type = 3. I added a histogram on res_entity_type so that when the query asks for rows where res_entity_type = 1, at least the optimizer will use the index for that query.
    If the query asks for rows where res_entity_type = 3, it should never use an index if the query is just based on that column. It would be more efficient to do the full table scan.
    --I know that the 1st part is correct.
    Part2:
    That is why I added indexes that include that column
    along with others. For example, for queries that request rows where res_entity_type = 3 and where res_level = 5 (which has 18 rows in our database), the optimizer will go ahead and use an index that contains those two columns.
    What I am confused is the 2nd Part. Is what he saying true/correct ?
    thanks
    Sonali
    Sonali
    Sonali,
    I believe that you can drop index #1. When queries are issued that need to use the indexed column RES_ENTITY_TYPE, they can just as easily use index#3 as they can use index#1.
    -John
    It is true but it depends on the selectivity of res_level columns , does combined index increase selectivity, clustering factor.
    If cardinality is low, think bitmap , u can have multiple indexes with not much space degradation and enough performace improvement
    Sonali,
    Actually a better idea might be to rebuild your indexes like this :
    index 2 - res_level
    I did not look closesly enough the first time.
    Oracle can use 2 indexes at once, and since you have index 3 being essentially index1 + index2, yes I agree that you don't need it. Also, I think you can drop the last column off index 4 since it is already indexed in index1.
    I am assuming that your tables are analyzed and that you are using the cost based optimizer.
    -John
    be careful with bitmap indexes - you don't want to use them if the underlying table is changing very much. bitmap indexes are best in static tables (and yes with low cardinality)
    Thanks, but I still don't understand that what he wrote in Part2 is correct or not...
    Any one please help..
    I forgot to mention the index positions in my 1st post..
    index 2 - res_level
    index 3 - res_level(1), res_entity_type(2)
    index4 - res_int_ext8(1), res_entity_type(2) , res_status(3)
    Thanks a lot
    Sonali
    Sonali
    Belgium
    As I see it, your developer wants to be sure he gets a full table scan when he selects a value that returns many rows.
    I did a little test. I hope the results can help you.
    btw, i'm on 7.3.4
    Create table gdn ( nummer number(4), nummer number(4),tekst varchar2(20));
    create index gdn_i2 on gdn ( nummer,nummer2)
    I inserted records in the table
    nummer = 1 , nummer2 = 1, tekst = 'ONE'
    about 16000 records
    nummer = 1 , nummer2 = 2, tekst = '12'
    about 7 records
    nummer = 2 , nummer2 = 2, tekst = '2'
    about 4 records
    analyze table gdn compute statistics;
    analyze index gdn_i2 compute statistics;
    analyze table gdn compute statistics for columns nummer,nummer2;
    select count(1) from gdn where nummer=1;
    -- results in full table scan
    select count(1) from gdn where nummer=1 and nummer2=1;
    select count(1) from gdn where nummer=2;
    -- results in index scan using GDN_I2
    select count(1) from gdn where nummer=2 and nummer2=2
    If this is the result you developer wants to achieve,
    the index 2 is not necessary.
    Hope this helps
    Gert
