    I have two tables abc and xyz
    SQL> create table xyz (id number(10), name varchar2(20));
    Table created.
    SQL> create table abc (id1 number(10), name1 varchar2(20));
    Table created.
    SQL> insert into xyz values(1,'bbb');
    1 row created.
    SQL> insert into abc values(1,'aaa');
    1 row created.
    Now I want the output as following
    ID Name
    1 bbb
    1 aaa
    Is it posible? Let me know.
    I know I can do with union .
    But, If I have inserted the raw
    insert into abc values(3,'ccc');
    I DON"T WANT result like this
    ID NAME
    1 aaa
    1 bbb
    3 ccc
    I want the result as folloing
    ID NAME
    1 aaa
    1 bbb
    Let me know.
    ora_inf,
    Can you explain how you want to decide which rows to include in the result set.
    If your table contains:
    1 aaa
    2 bbb
    3 ccc
    How should I decide which of these rows to return? By id, name or ?
    Feb 2000
    Singapore
    If you only want to get the rows with id = 1
    then
    select * from abc where id = 1
    union
    select * from xyz where id = 1;
    Sanjay
    Jul 2000
    if you want to join tables then:
    select a.*
    from abc a,
    xyz b
    where a.id = b.id
    union
    select b.*
    from abc a,
    xyz b
    where a.id = b.id
    shawish_sababa
    shawish_sababa@hotmail.com
