I have a user A who owns several tables. Now, I want to grant select, update, delete, insert on all of user A's tables to user B. For this, I have written the following in grant.sql which I run after logging in as user A:
grant.sql:
declare
cursor c_tables is select table_name from user_tables;
v_tables c_tables%ROWTYPE;
open c_tables;
loop
fetch c_tables into v_tables;
exit when c_tables%notfound;
grant select, insert, update, delete on v_tables.table_name to B;
end loop;
close c_tables;
end;
But this does not work. It says, "grant not allowed". How can I correct this, or is there a better way to do it ?
set verify off
set term off
set heading off
set feedback off
set pause off
set trimspool on
set linesize 1024
set pagesize 0
clear breaks
clear columns
spool grant.sql
select 'grant select, insert, update, delete on '||
table_name || ' to USER_A;'
from user_tables;
It's because grant is data control language(not allowed in procedures) and not DML.
You have to use EXECUTE IMMEDIATE for 8 version or
use dbms_sql package for version bellow 8:
here a procedure for delete a oracle user (data definition language)
PROCEDURE DeleteUser(user_id IN NUMBER,
errorcode OUT NUMBER)
IS
v_CreateCommand VARCHAR2(120);
v_Dummy INTEGER;
v_CursorID INTEGER;
ausername VARCHAR2(80);
errorcode :=0;
ausername:='';
SELECT login_id INTO ausername FROM broker_codes
WHERE brc_id = user_id;
UPDATE BROKER_CODES
SET login_id = ''
Where brc_id = user_id;
COMMIT;
v_CreateCommand := 'DROP USER ' || ausername ;
v_CursorID := DBMS_SQL.OPEN_CURSOR;
DBMS_SQL.PARSE(v_CursorID, v_CreateCommand, DBMS_SQL.NATIVE);
v_dummy := DBMS_SQL.EXECUTE(v_CursorID);
DBMS_SQL.CLOSE_CURSOR(v_CursorID);
EXCEPTION
WHEN OTHERS THEN
errorcode:= SQLCODE;
End DeleteUser;
