    Mar 2000
    Hi there, I have been away from Oracle for a while and so I have forgotten some things. I remember that there was a command that would show the query execution plan for each query. It was set for a user and after it was set, every query by the user would show the execution plan. Could you kindly tell me what that command is? Thank you.
    Afshin.
    If you have Plan table created in the Schema,
    Use This
    Set Autot On
    This will help
    Thanks..
    Dallas:TX:USA
    set autotrace on;
    Rajeev Suri
    Mar 2000
    Thanks you very much guys
    Afshin.
