Hello,
I executed the sql script & the sqlloader commands to create, load and index the table SYSTEM.HELP.
When I launch the command HELP <...> in sqlplus environment installed in the Server (HP-UX), it works fine.
From an NT client, when I launch the command HELP <...>, I have the following message :
Can't open the help file !
I executed the set of scripts under $ORACLE_HOME/sqlplus/admin/help (on the Unix server) in order to create the HELP table & load data related to sql, sql+ & plsql help.
From sql*plus client installed in the server (Unix server), the command HELP <...> works fine.
From NT sql*plus client : the command HELP doesn't work (message : Can't open the help file ! ).
