Thread: import problem
    Help, Here is the scenario. I am trying to import a schema (for days now) from a database on another machine to a new machine. I have created all the tablespaces, roles, users, etc. Some tables import ok others are getting an error.
    Below is the tablespaces from the old database.
    TABLESPACE_NAME INITIAL_EX NEXT_EXTEN MIN_EXTENT MAX_EXTENT PCT_INCREA MIN_EXTLEN STATUS CONTENTS LOGGING
    SYSTEM 12288 12288 1 249 50 0 ONLINE PERMANENT LOGGING
    RBS 1048576 1048576 10 249 0 0 ONLINE PERMANENT LOGGING
    TEMP 1048576 1048576 1 2147483645 0 0 ONLINE TEMPORARY LOGGING
    TOOLS 20480 20480 1 249 50 0 ONLINE PERMANENT LOGGING
    USERS 20480 20480 1 249 50 0 ONLINE PERMANENT LOGGING
    MY 16384 8192 1 2147483645 0 0 ONLINE PERMANENT LOGGING
    SPA_DATA 20480 40960 1 2147483645 0 0 ONLINE PERMANENT LOGGING
    BUS_DATA 20480 40960 1 500 0 0 ONLINE PERMANENT LOGGING
    MY_INDEX 20480 40960 1 2147483645 0 0 ONLINE PERMANENT LOGGING
    9 rows selected.
    Tablespaces from the new database.
    BUS_DATA 20480 40960 1 2147483645 0 0 ONLINE PERMANENT LOGGING
    9 rows selected.
    Error from Import:
    ORA-01658: unable to create INITIAL extent for segment in tablespace MY_INDEX
    IMP-00017: following statement failed with ORACLE error 1658:
    "CREATE INDEX "S30_IX2" ON "S30" ("SP_FID" ) PCTFREE 5 INITRANS 2 MAXTRANS "
    "255 STORAGE (INITIAL 409600 NEXT 102400 MINEXTENTS 1 MAXEXTENTS 500 PCTINCR"
    "EASE 0 FREELISTS 1 FREELIST GROUPS 1 BUFFER_POOL DEFAULT) TABLESPACE "SDE_I"
    "NDEX" LOGGING"
    IMP-00003: ORACLE error 1658 encountered
    . . importing table "S31" 7855 rows imported
    "CREATE UNIQUE INDEX "S31_IX1" ON "S31" ("GX" , "GY" , "EMINX" , "EMINY" , ""
    "EMAXX" , "EMAXY" , "SP_FID" ) PCTFREE 5 INITRANS 2 MAXTRANS 255 STORAGE (I"
    "NITIAL 1024000 NEXT 102400 MINEXTENTS 1 MAXEXTENTS 500 PCTINCREASE 0 FREELI"
    questions:
    *** I am assumming that the import is trying to create an initial extent for index s30_IX2 of 409600,
    and an initial extent for index s31_IX1 of 1024000. the old database had an initial extent of 20480. How did these extents get larger than 20480?
    ***same thing with the next extent was to be 40960 but both of these next extents are looking for 102400. How did they grow bigger than the original storage.
    ***Is this the reason why my import fails?
    ***What do you sugget I do, increasing the initial and next extent seems very high. Is this ok to do?
    Kathy
    Apr 2000
    roma
    exp - imp eliminate the segment extent, so if you have a segment made on 10 extnets...you'll have e segment made on 1 extent (as sum of old extents). So increase the tablespace size and retry the import (only of the table failed...after droping the new one). i don't sugest you change the initial extent of the index because in creation it will take all the extents necessary for the creation ...(and prob. you'll take error)
    Feb 2000
    Washington DC
    I guess while taking export you mentioned compress=y so its trying to compress the exisiting data to 1 extent and placing into 1 single extent while importing.
    couple of options to deal with.
    choose compress=n option for export.
    else try first importing with no data rows=n and then data with rows=y
    create tablespace with enough space.
