ORACLE Startup Problem
Thread: ORACLE Startup Problem
    Aug 2014
    Need some help in starting up an Oracle instance which was working fine a day ago.
    SQL> startup
    ORACLE instance started.
    Total System Global Area 3140026368 bytes
    Fixed Size                  2257352 bytes
    Variable Size             973082168 bytes
    Database Buffers         2147483648 bytes
    Redo Buffers               17203200 bytes
    Database mounted.
    ORA-01092: ORACLE instance terminated. Disconnection forced
    ORA-01360: invalid token
    Process ID: 30562
    Session ID: 1030 Serial number: 5
    Error from the alert log:
     pid='30562'>
     Errors in file /u01/app/oracle/diag/rdbms/mcsw/MCSW/trace/MCSW_ora_30562.trc:
    Extract from trc file:
    ----- Recovery Hash Table Statistics ---------
    Hash table buckets = 262144
    Longest hash chain = 1
    Average hash chain = 27/27 = 1.0
    Max compares per lookup = 1
    Avg compares per lookup = 157/184 = 0.9
    *** 2014-08-09 02:22:07.195
    KCRA: start recovery claims for 27 data blocks
    *** 2014-08-09 02:22:07.199
    KCRA: blocks processed = 27/27, claimed = 27, eliminated = 0
    *** 2014-08-09 02:22:07.201
    Recovery of Online Redo Log: Thread 1 Group 1 Seq 22 Reading mem 0
    *** 2014-08-09 02:22:07.207
    Completed redo application of 0.02MB
    Completed recovery checkpoint
    Avg compares per lookup = 184/184 = 1.0
    Recovery sets nab of thread 1 seq 22 to 110 with 8 zeroblks
    *** 2014-08-09 02:22:09.970
    kwqmnich: current time::  0: 22:  9: 0
    kwqmnich: instance no 0 repartition flag 1
    kwqmnich: initialized job cache structure
    *** 2014-08-09 02:22:11.571
    USER (ospid: 30562): terminating the instance due to error 1360
    Any help is much appreciated.
    Feb 2014
    Is this part of a cluster or is it a standalone?
    Check hidden parameter:
    select name, value from v$parameter
    where name= '_kgl_debug'
    Aug 2014
    If this is a RAC instance, pl check the value of parameter _KGL_DEBUG. It should be different across all instances. However, I would recomend do not set this para
    meter directly without consulting Oracle support
    Harvinder
    Aug 2007
    Cyberjaya,kuala lumpur
    Please refer this Oracle metalink note, it will be helpful. (Doc ID 1604879.1)
    Thanks/Gopu
