Scripting Tools
Results 1 to 7 of 7
Thread: Scripting Tools
    Feb 2014
    Question Scripting Tools
    What are some of the scripting tools commonly used in the industry?
    Share on Google+
    Quote Originally Posted by rishwish View Post
    You need to start with what OS and version of Oracle you are using. Mostly the OS though. You should also mention any scripting tools that you have already used. However, if you use Linux or a more recent version of Unix, then you should start by learning Bash. You can do just about anything that you want with Bash. If there is something specific that Bash doesn't give you then there is either a Perl "one-liner" that you can find from Google, or a Perl library with numerous code examples.
    If you are using Windows, then you should download and install Cygwin for Windows. Then make sure that the C:\Cygwin\bin directory is always in your path. Assuming you install Cygwin to C:\Cygwin. Cygwin is not as good as Bash, but it allows you to do things that you can't do without Bash. With Cygwin utilities you need to use the Cygwin directory structure shown below. pwd is the command to show the current path.
    C:\Windows\system32>pwd
    /cygdrive/c/Windows/system32
    Then you need to look at other peoples code, try to understand all of the Linux commands and try writing your own scripts.
    Just don't start with writing scripts that do destructive things like delete, move files, etc. And find, grep, sed and awk are
    your friends use them often.
    Share on Google+
    Lake Worth, FL
    Cool
    Top tool is: vi
    Share on Google+
    Quote Originally Posted by LKBrwn_DBA View Post
    Top tool is: vi
    vi?!?!?!?! Why not vim?
    That's fine as long as you aren't one of those emacs people!
    Share on Google+
    Feb 2014
    Thank you gandolf. I am a rookie and everything you said above is extremely helpful. Mucho Thanks!
    Share on Google+
    Feb 2014
    Thank you LKBrwn
    Share on Google+
    Feb 2014
    Thank you for all your help guys!
    Share on Google+
