unable to srtart DBMS_JOB . need help
Thread: unable to srtart DBMS_JOB . need help
    Hello,
    we are not able to start dbms_jobs
    when i query the database, i see..
    select value from dba_scheduler_global_attribute where attribute_name='SCHEDULER_DISABLED';
    VALUE
    TRUE
    I then disable it with - exec dbms_scheduler.set_scheduler_attribute('scheduler_disabled','FALSE');
    if i query again, i dont see any values for SCHEDULER_DISABLED and it shows nothing.
    how to solve this, we are not able to run any jobs now.
    thanks
    What is the value for job_queue_processes?
    SYS@cadxdc AS SYSDBA> show parameter job_queue_processes
    NAME                                 TYPE                              VALUE
    job_queue_processes                  integer                           100
    Here are some queries that will show you what is running for both dbms_scheduler and dbms_jobs.
    There are two basic ways to run job in a database dbms_scheduler and dbms_jobs.
    set echo off
    col owner           format a15
    col JOB_ACTION      format a50
    col JOB_NAME        format a30
    col JOB_TYPE        format a20
    col START_DATE      format a17
    col NEXT_RUN_DATE   format a17
    col LAST_START_DATE format a17
    set linesize 230
    set pagesize 0
    select 'dbms_scheduler jobs' from dual;
    set pagesize 100
    select owner, job_name, enabled, job_action,
    TO_CHAR(LAST_START_DATE, 'DD-MON-YYYY:HH24:MI') LAST_START_DATE,
    TO_CHAR(start_date,      'DD-MON-YYYY:HH24:MI') start_date,
    TO_CHAR(NEXT_RUN_DATE,   'DD-MON-YYYY:HH24:MI') NEXT_RUN_DATE
    from ALL_SCHEDULER_JOBS
    order by enabled, owner, job_name;
    col what      format a60
    col log_user  format a35
    col interval  format a40
    col last_date format a18
    col next_date format a18
    set pagesize 0
    select 'dba_jobs' from dual;
    set pagesize 100
    select job, log_user,
    TO_CHAR(last_date, 'DD-MON-YYYY:HH24:MI') last_date,
    TO_CHAR(next_date, 'DD-MON-YYYY:HH24:MI') next_date,
    interval, broken, what
    from dba_jobs
    order by 2,3;
    set echo on
    Thanks. The value is 200 for job_queue_processes
    You should also make sure that the end date is not in the past and that the job has been enabled.
