Oracle SQL Developer Describe Command
Thread: Oracle SQL Developer Describe Command
    Dec 2013
    Buffalo NY
    Hi Everybody,
    I have a database for a fictional school. It contains tables for faculty, students, course, section, term, enrollment, etc.
    I am trying to write a script that provides all of the information in, and duplicates the formatting of, Oracle's SQL*Plus describe command. The output should add the comments on the rows. the input is: owner (system) and table name (term (or any of my tables)). Output should be: columns for Name, Null?, Type, Comments.
    I enter "system" as owner and Term for table, but the only thing returned is the name of the table, not the other information I need.
    My script looks like this:
    SELECT table_name
    FROM all_tables
    WHERE owner = UPPER('&schemaowner')
    AND table_name LIKE UPPER('%&table%');
    This is the output:
    old:SELECT table_name
    FROM all_tables
    new:SELECT table_name
    FROM all_tables
    WHERE owner = UPPER('system')
    AND table_name LIKE UPPER('%term%')
    TABLE_NAME
    TERM
    Thank you
    Have you looked at either dba_tab_columns or user_tab_columns? Also if you are looking at objects in the schema
    that you are logged in as don't use the all_* views, use the user_* views. As in user_tables, user_tab_columns.
    Between user_tables, user_tab_columns and possibly user_cons_columns you should have everything that you need.
    There is also user_ind_columns in case that helps too.
    Dec 2013
    Buffalo NY
    thanks for getting back to me Gandolf.
    First of all your suggestions might be good, but I am a bit confused.
    Yes, I, logged in a system. I'm not sure where to put your suggestions. Are you saying user_*views should be in the select statement? I'm not really sure whay my query should look like. I'm rather new at this.
    Thanks for your help.
    Which schema owns the objects that you are looking at? If you are logged in as system, then you should
    use the dba_* views. Such as dba_tables, dba_tab_columns, dba_cons_columns and dba_ind_columns.
    From a design perspective, you should not create any objects in sys or system.
    Dec 2013
    Buffalo NY
    Well, Gandolf, I guess I just don't get it. It seems like it should be a simple problem, but no matter what i try I get an error, or just the name of the table is returned. as in:
    SELECT table_name
    FROM dba_tables
    Output: term (that was the name of the table I entered at the prompt)
    typo
    if you are looking for the columns and their attributes you should be selecting from dba_tab_columns, filtering by table_name and sorting by table_name if selecting more than one table.
