Query Help - Merging two rows
Results 1 to 7 of 7
Thread: Query Help - Merging two rows
    Oct 2013
    PFB the sample data.
    CREATE TABLE "MY_TABLE"
    ("NBR" VARCHAR2(20 BYTE),
    "MO_YR" NUMBER,
    "EFF_DT" DATE
    INSERT INTO MY_TABLE (NBR, MO_YR, EFF_DT) VALUES('101',201310,Sysdate-20);
    INSERT INTO MY_TABLE (NBR, MO_YR, EFF_DT) VALUES('102',201310,Sysdate-15);
    INSERT INTO MY_TABLE (NBR, MO_YR, EFF_DT) VALUES('103',201310,Sysdate-10);
    INSERT INTO MY_TABLE (NBR, MO_YR, EFF_DT) VALUES('104',201310,Sysdate-5);
    INSERT INTO MY_TABLE (NBR, MO_YR, EFF_DT) VALUES('105',201310,Sysdate);
    COMMIT;
    SELECT * FROM MY_TABLE;
    Here, i need to get a dataset like this.
    Prev. | Old | Eff DT
    105 104 Sysdate
    104 103 Sysdate-5
    103 102 Sysdate-10
    102 101 Sysdate-15
    As you can see, i need to merge the two consecutive records in the above fashion. Thanks in advance.
    Lake Worth, FL
    Try using the one of these analytic functions: LAG or LEAD.
    Perhaps you could learn about analytic functions if you Read This Fine Manual:
    OracleŽ Database SQL Language Reference
    Oct 2013
    Quote Originally Posted by LKBrwn_DBA View Post
    Thank you Good sir,
    I know most of these functions and use them often. But, this requirement of mine is lil twisted and i just can not figure out how to do it. Anyways, thanks for writing in.
    Hoping for some help on this.
    -Parthiban
    Oct 2013
    NBR AS CURR_NBR,
    LAG(NBR, 1, 0) OVER (PARTITION BY MO_YR
    ORDER BY MO_YR, EFF_DT) AS PREV_NBR.
    Oct 2013
    Sorry i clicked report button by mistake.
    Quote Originally Posted by ParthibanSekar View Post
    I'm not sure if that feature even works...
    Lake Worth, FL
    Cool
    Yep, you got it:
    SQL> WITH my_table (nbr, mo_yr, eff_dt)
      2    AS (SELECT '101', 201310, TRUNC ( SYSDATE - 20) FROM DUAL UNION ALL
      3        SELECT '102', 201310, TRUNC ( SYSDATE - 15) FROM DUAL UNION ALL
      4        SELECT '103', 201310, TRUNC ( SYSDATE - 10) FROM DUAL UNION ALL
      5        SELECT '104', 201310, TRUNC ( SYSDATE -  5) FROM DUAL UNION ALL
      6        SELECT '105', 201310, TRUNC ( SYSDATE     ) FROM DUAL)
      7  SELECT nbr AS curr_nbr
      8       , LAG ( nbr, 1, 0)
      9           OVER ( PARTITION BY mo_yr ORDER BY mo_yr, eff_dt) AS prev_nbr
     10       , eff_dt
     11    FROM my_table
     12*  ORDER BY eff_dt desc
    SQL> /
    CURR_NBR  PREV_NBR  EFF_DT
    105       104       28-Oct-2013 00:00:00
    104       103       23-Oct-2013 00:00:00
    103       102       18-Oct-2013 00:00:00
    102       101       13-Oct-2013 00:00:00
    101         0       08-Oct-2013 00:00:00
    SQL>
