Using 'between' operator for varchar columns
Thread: Using 'between' operator for varchar columns
    Sep 2013
    Question Using 'between' operator for varchar columns
    I have a table with a varchar2 (80 char) column storing values 'sc51' through 'sc60'. When I run the following SQL I see all the values:
    select vartest from vartest_tbl
    where (upper(vartest) between upper('sc51') and upper('sc99') );
    sc51
    sc52
    sc53
    sc54
    sc55
    sc56
    sc57
    sc58
    sc59
    sc60
    But when I run the following SQL I don't see any values:
    where (upper(vartest) between upper('sc51') and upper('sc100') );
    And if I change the SQL to:
    where (upper(vartest) between upper('sc51') and upper('sc600') );
    I see all the values again.
    Using:
    where (upper(vartest) between upper('sc51') and upper('sc599') );
    shows me values between 'sc51' - 'sc59' only.
    Can you explain this behavior? What do I need to do to get the correct queryset every time?
    Thank you.
    its because it is just text, it doesn't understand you have 2 letters then 3 numbers
    so nothing is between sc51 and sc100 as 1 comes before 5 in the checking, so nothing returned, when you select 600 it works as 6 comes after 5
    you will need to split the value up based on the 3rd character and above in your example
    You could split the column into a two character code, and a separate column that would be a number.
    i.e. where type='SC' and code between 51 and 100;
    Sep 2013
    Thank you.
