    Jul 2013
    Temp Tables within Stored Procedure
    I'm pretty new to Oracle, but I have been developing in MS SQL for about 15. So I'm still getting use to the syntax and features within Oracle.
    I'm trying to create a stored procedure that has two temporary tables within it, and then queries both them tables and inserts the results into a table.
    I created the script but when they try to run in on the server it wont run. Can you guys tell me what I'm doing wrong?
    CREATE OR REPLACE PROCEDURE UpdateFIDB_SP
    IS
            CREATE GLOBAL TEMPORARY TABLE myAAAA
            AS
                  (SELECT  AAAA.1111, AAAA.2222, BBBB.3333_EXT, CCCC.4444, DDDD.5555, DDDD.6666, DDDD.7777,
                          DDDD.8888, AAAA.9999, EEEE.1010, EEEE.1A1A, EEEE.1B1B, FFFF.3333_LO, FFFF.1C1C,
                          AAAA.1D1D
                  FROM mySchema.FFFF_07 FFFF
                  RIGHT OUTER JOIN mySchema.EEEE EEEE ON FFFF.9999 = EEEE.1B1B
                  RIGHT OUTER JOIN (
                                    mySchema.DDDD DDDD
                                    RIGHT OUTER JOIN mySchema.AAAA AAAA ON DDDD.1D1D = AAAA.1D1D
                                    ) ON EEEE.PSPNR = AAAA.9999
                  LEFT OUTER JOIN mySchema.CCCC CCCC ON AAAA.3333 = CCCC.3333
                  LEFT OUTER JOIN mySchema.BBBB BBBB ON AAAA.3333 = BBBB.3333_INT
                  GROUP BY  AAAA.1D1D, AAAA.1111, AAAA.2222, BBBB.3333_EXT, CCCC.4444, DDDD.5555, DDDD.6666,
                            DDDD.7777, DDDD.8888, AAAA.9999, EEEE.1010, EEEE.1A1A, EEEE.1B1B, FFFF.3333_LO,
                            FFFF.1C1C
            ON COMMIT DELETE ROWS);
            CREATE GLOBAL TEMPORARY TABLE myGGGG
            AS
                (SELECT  GGGG.1E1E, GGGG.1F1F, GGGG.1G1G, GGGG.1H1H, GGGG.1I1I, GGGG.1J1J,
                        GGGG.1K1K, GGGG.R1D1D, GGGG.1L1L, GGGG.1M1M, GGGG.1N1N, GGGG.1O1O, GGGG.1P1P,
                        GGGG.1Q1Q, HHHH.1R1R, IIII.1S1S, IIII.1T1T, IIII.1U1U, IIII.1V1V
                FROM  mySchema.IIII IIII
                      INNER JOIN mySchema.GGGG GGGG ON IIII.1K1K = GGGG.1K1K
                      LEFT OUTER JOIN mySchema.HHHH HHHH ON GGGG.1L1L = HHHH.1W1W
                WHERE ( GGGG.1M1M IN ('20', '30') )
                AND   ( TO_DATE(IIII.1V1V, 'dd-mon-yyyy') = TO_DATE('31-DEC-9999','dd-mon-yyyy') )
                AND ( TO_DATE(GGGG.1N1N, 'dd-mon-yyyy') >= TO_DATE('01-Jan-2011','dd-mon-yyyy') )
            TRUNCATE TABLE FIDB;
            INSERT INTO FIDB (1111, 2222, 3333_EXT, 4444, 5555, 6666, 7777, 8888, 9999,
                                      1010, 1A1A, 1B1B,3333_LO, 1C1C, 1D1D, 1E1E, 1F1F, 1G1G,
                                      1H1H, 1I1I, 1J1J, 1K1K, R1D1D, 1L1L, 1M1M, 1N1N,
                                      1O1O, 1P1P, 1Q1Q, 1R1R, 1S1S, 1T1T, 1U1U, 1V1V)
            SELECT  myAAAA.1111, myAAAA.2222, myAAAA.3333_EXT, myAAAA.4444, myAAAA.5555, myAAAA.6666,
                    myAAAA.7777, myAAAA.8888, myAAAA.9999, myAAAA.1010, myAAAA.1A1A, myAAAA.1B1B,
                    myAAAA.3333_LO, myAAAA.1C1C, myAAAA.1D1D, myGGGG.1E1E, myGGGG.1F1F, myGGGG.1G1G,
                    myGGGG.1H1H, myGGGG.1I1I, myGGGG.1J1J, myGGGG.1K1K, myGGGG.R1D1D,
                    myGGGG.1L1L, myGGGG.1M1M, myGGGG.1N1N, myGGGG.1O1O, myGGGG.1P1P,
                    myGGGG.1Q1Q, myGGGG.1R1R, myGGGG.1S1S, myGGGG.1T1T, myGGGG.1U1U, myGGGG.1V1V
            FROM myGGGG INNER JOIN myAAAA ON myGGGG.R1D1D = myAAAA.1D1D
            ORDER BY myGGGG.R1D1D;
       COMMIT;
    If you want real help, you should let people know what error message you are getting.
    If you want something, that may or may not solve your problem, then I suggest the Magic 8 ball...
    http://web.ics.purdue.edu/~ssanty/cgi-bin/eightball.cgi
    Lake Worth, FL
    Cool
    Oracle temporary tables are statically defined, you can learn all about them by Reading The Fine Manual: OracleŽ Database Administrator's Guide
