Sql script that compares two db,s and updates db and insert date of update
Thread: Sql script that compares two db,s and updates db and insert date of update
    May 2013
    Hi i need some help creating an sql script that can update info from one table in dbase1 to another table in dbase2 that has the same columns and if posible insert date and time in one column when the syncronized is done? Can anyone help mee whit this?
    Lake Worth, FL
    Cool
    Quote Originally Posted by miguel_q View Post
    1) Create database link.
    2) Use MERGE statement.
    May 2013
    help with creating the procedure
    how can i create this query on a procedure:
    Insert into COMPUSOFT.PESAJE@DB_2
    (PSJ_GESTION, PSJ_COD, PSJ_PLACA, PSJ_PESO, PSJ_FECHA,
    PSJ_ESTADO, BLZ_COD, MNF_COD, DMN_COD,
    USR_COD, PSJ_OPERACION, TIC_COD, PSJ_TARA, PSJ_NETO)
    select /*+ FULL(Tbl1) */
    , PSJ_ESTADO, BLZ_COD, MNF_COD, DMN_COD, USR_COD
    from COMPUSOFT.PESAJE Tbl1
    where PSJ_OPERACION='IMP'
    minus
    select /*+ FULL(Tbl2) */
    from COMPUSOFT.PESAJE@"DB_2" Tbl2
    where PSJ_OPERACION='IMP';
    plus i would like to insert also that when it runs the query also change a value in table pesaje column dmn_cod to "yes" default "no" in db_2
    any help please???
Tags for this Thread
