How to use >= on a varchar2 datatype
Thread: How to use >= on a varchar2 datatype
    Dec 2012
    I have a table which has a column called "CUSTOMER_ID" and datatype of varchar2.
    I need to select all the rows with a value greater than 1013986 so I try using:
    select * from TABLE.A1_Cust_Cont WHERE CUSTOMER_ID>'1013986' order by CUSTOMER_ID asc;
    But it selects all the rows in the table - including numbers smaller. I assume I need to let SQL know to look at the CUSTOMER_ID column as a number.
    Any help would be appreciated.
    Lake Worth, FL
    Cool
    Oracle is behaving as expected. If you have a bad design, you get bad results.
    You could force "numeric" comparison by left padding the column with zeroes:
    SELECT *
      FROM table_a1
     WHERE LPAD ( customer_id, 32, '0') >= LPAD ( '1013986', 32, '0')
     ORDER BY customer_id ASC
    Dec 2012
    Exactly what I needed - thanks so much
