    Oct 2012
    Decode Function issue
    Hi all,
    i want compare two rows in a table. so i used decode function to compare the values, whther its matched or not.
    One of my table column has Long data type.
    Decode(a.col1,b.col1,'Match','NotMatch')
    col1 - is long data type.
    when i use long data type, i got below error,
    is there anyway to rectify this error.
    SQL Error: ORA-00932: inconsistent datatypes: expected NUMBER got LONG
    00932. 00000 - "inconsistent datatypes: expected %s got %s"
    Thanks in advance.
    Santhosh
    LONG columns are pretty restictive, one of the restrictions is that they cannot be used on built-in functions.
    Try using the to_clob() function, and then you can also use all of the methods of dbms_lob. As in:
    select dbms_lob.compare(to_clob(tab_a.mycolumn), to_clob(tab_b.mycolumn))
    from table_a
    inner join table_b
    on table_a.pkey = table_b.pkey
    where table_a.pkey.123456;
