    Aug 2012
    Exclamation ORA-01578: ORACLE data block corrupted (file # 1, block # 2)
    I can't able to connet to the database, while connecting i'm receiving the below error:
    ERROR: ORA-01034: ORACLE not available
    I shutdown the database and restarted it, while during this process i face new error :
    Can any one help me to sort this out?
    SQL*Plus: Version 3.0.11.1.2 - Production on Thu Aug 23 15:04:50 2012
    Copyright (c) Oracle Corporation 1979, 1992. All rights reserved.
    Enter user-name: netmon
    Enter password:
    ORA-07318: smsget: open error when opening sgadef.dbf file.
    SunOS Error: 2: No such file or directory
    You posted this question in the wrong forum, so I moved it to the correct forum.
    This is one reason why you want to use RMAN to backup your database. You can do block level recovery with RMAN. You should probably get an RMAN backup now before you try to recover any blocks, if you don't already have an RMAN backup.
    Here is a document on getting started with RMAN
    http://docs.oracle.com/cd/B28359_01/...0/rcmquick.htm
    Here is a document for doing block level recovery.
    http://docs.oracle.com/cd/B28359_01/...0/rcmblock.htm
    Block level corruption should not happen as a matter of course, however it is relatively easy to deal with, once you have a good backup and recovery strategy.
