    May 2012
    current_timestamp and sysdate are diffrent.
    I am facing a problem of having difference in sysdate and current_timestamp. Server date matches with sysdate but not with current_timestamp.
    $ sqlplus / as sysdba
    SQL*Plus: Release 11.2.0.1.0 Production on Wed May 30 16:29:04 2012
    Copyright (c) 1982, 2009, Oracle. All rights reserved.
    Connected to:
    Oracle Database 11g Enterprise Edition Release 11.2.0.1.0 - 64bit Production
    With the Partitioning, Oracle Label Security, OLAP, Data Mining,
    Oracle Database Vault and Real Application Testing options
    SQL> SELECT CURRENT_TIMESTAMP,to_char(sysdate, 'Dy DD-Mon-YYYY HH24:MI:SS') as "Now" from dual;
    CURRENT_TIMESTAMP
    Now
    21-JUN-12 05.29.22.503772 PM +00:00
    Wed 30-May-2012 16:29:22
    SQL> !date
    Wed May 30 16:29:26 IST 2012
    Please Help
    SYSDATE returns the date and time that belongs to the host where the database is sitting as reported by the Operating System.
    On the other hand, CURRENT_TIMESTAMP depends on the session.
    May 2012
    PAVB,
    Thanks for reply. But this fact is known to me. I have already check the OS date and not changed current timestamp. Still facing same problem.
    Are you in the same timezone as the database server? Because it could be that CURRENT_TIMESTAMP is specific to the time on the client machine, rather than the server. Just a thought...
    Quote Originally Posted by maheop View Post
    It is the other way around, SYSDATE depends on the server while CURRENT_TIMESTAMP depends on the session a.k.a. the client session.
    Oct 2008
    difference of few hours can be understood...but you are having 21 days diff..there is definetely somthing wrong...
    SELECT SESSIONTIMEZONE, CURRENT_TIMESTAMP FROM DUAL;
    can you paste the output?
