Archive logs getting applied on standby & not getting updated on Primary- No Lag
Thread: Archive logs getting applied on standby & not getting updated on Primary- No Lag
    Dec 2001
    Baltimore, MD
    Hello all
    I am facing a situation that I see no documentation about.
    Archive logs are getting applied on remote physical standby but are not getting updated on primary Database.
    I have attempted to reset the process with the following commands but not seeing much improvement.
    alter system set log_archive_dest_state_2 =’defer’;
    alter system set log_archive_dest_state_2 =’enable’;
    I am still looking into this however I was just wondering if you have any suggestion/solution
    STANDBY DATABASE
    SQL> select * from v$archive_gap;
    no rows selected
    SQL>
    Ablakios
    Arsene Lupain
    The lie takes the elevator, the truth takes the staircase but ends up catching up with the lie.
    Did you look at the alert log for the standby database? Are you using dataguard? If so you should verify the settings for fal_server and fal_client.
    Lake Worth, FL
    Cool
    If you are using Dataguard, you need to reset using dataguard commands.
    Besides, if your Oracle version is 11.2.0.1, then there is a dataguard/rman bug and a work-around to fix it.
    If you are NOT using Dataguard, then you are on your own.
    Dec 2001
    Baltimore, MD
    No I am not using Dataguard.
    Thanks for the quick response
    Arsene Lupain
