Need help with stored proc...driving me nuts
Thread: Need help with stored proc...driving me nuts
    Nov 2010
    It's been a while since I've had to write any pl/sql code. I've been banging my head against this problem for hours and can't figure it out.
    Basically what I'm trying to do is copy the records in a table with a bunch of columns into a key-value pair format. The key-value formatted table is defined as:
    SQL> desc contactskvp;
    Name Null? Type
    CONTACT VARCHAR2(100)
    KEY VARCHAR2(20)
    VALUE VARCHAR2(4000)
    So I tried starting with a simple stored procedure:
    create or replace procedure ConvertToKvp as
    TYPE loc_array_type IS TABLE OF VARCHAR2(40);
    dml_str1 varchar2(200);
    loc_array loc_array_type;
    my_rec user_tab_columns.column_name%type;
    -- bulk fetch emtsearchablecontact column names
    SELECT column_name BULK COLLECT INTO loc_array
    FROM user_tab_columns where table_name='EMTSEARCHABLECONTACTS' and column_name not in ('ID');
    FOR i in loc_array.first..loc_array.last LOOP
    select column_name into my_rec from user_tab_columns where table_name='CONTACTTABLE' and column_name = loc_array(i);
    dml_str1 := 'INSERT INTO CONTACTSKVP(contact,key,value) select id,'||my_rec||','||loc_array(i)
    ||' FROM CONTACTTABLE WHERE '||loc_array(i)
    ||' IS NOT NULL';
    execute immediate dml_str1;
    commit;
    END LOOP;
    The procedure compiles fine and executes ok but when I look at the data I expect to see something like
    CONTACT,KEY,VALUE
    1,TEXT121,Jim
    1,TEXT122,Taylor
    1,TEXT141,93 E. Sycamore St.
    but what I'm getting instead is:
    1,Jim,Jim
    1,Taylor,Taylor
    1,93 E. Sycamore St., 93 E. Sycamore St.
    Any ideas what is happening here? I'm not even sure how my_rec could be getting the column value from contacttable when it's query is selecting from user_tab_columns.
    Also if you could give me an idea of what I'd have to do to get the expected behavior it would be greatly appreciated.
    Thanks!
    Lake Worth, FL
    Wink Quotes, it's all about the quotes...
    Try this, and next time please format your code:
    CREATE OR REPLACE PROCEDURE ConvertToKvp
    AS
       TYPE loc_array_type IS TABLE OF VARCHAR2 (40);
       dml_str1    VARCHAR2 (200);
       my_rec      user_tab_columns.column_name%TYPE;
       SELECT column_name
         BULK COLLECT
         INTO loc_array
        WHERE table_name = 'EMTSEARCHABLECONTACTS' AND column_name NOT IN ('ID');
       FOR i IN loc_array.FIRST .. loc_array.LAST
       LOOP
          SELECT column_name
            INTO my_rec
           WHERE table_name = 'CONTACTTABLE' AND column_name = loc_array (i);
          dml_str1 :=
                'INSERT INTO CONTACTSKVP(contact,key,value) select id,'''
             || my_rec
             || loc_array (i)
             || loc_array (i)
             || ' IS NOT NULL';
          EXECUTE IMMEDIATE dml_str1;
          COMMIT;
       END LOOP;
    Nov 2010
    Thanks!
    That did the trick thanks so much for responding!
    Sorry about the code formatting - I'll make sure to remember next time
