Thread: sql loader Help: "oravsn8.dll" not found!!!
    hi guys,
    what is the command for invoking the sql loader under windows NT/2000 system?
    when I type "sqlldr /?" in the command prompt, i got the error message "the dynamic link library oravsn8.dll could not be found in the specified path......" so i search my machine for the "oravsn8.dll", but the file doesn't exist.
    thg
    Feb 2000
    Washington DC
    'sqlldr' at the dos prompt should work. If it doesn't check the path and see Oracle_Home/bin is in the path and try.
    Otherwise try search and find the executable for sqlldr and double click it.
    If both of then doesn't work, I guess installation might have not been perfect. You might need to relink your executables.
    Could be a problem with dll, if its Win 2000. Seems its bug as metalink doc says.
    [url]http://metalink.oracle.com/metalink/plsql/ml2_documents.showDocument?p_database_id=NOT&p_id=94295.1[/url]
    [Edited by sreddy on 01-24-2001 at 04:44 PM]
    thanks.
    i copied the oravsn8.dll from another machine and it is working now. It was probably an installation problem.
