Results 1 to 10 of 10
    Jul 2010
    oracle startup problem on IBM AIX server
    I am not able to do the normal startup of oracle 10g in IBM AIX server I posting the error log.
    Need help in resolving this problem
    Mon Jul 5 17:02:11 2010
    Starting ORACLE instance (normal)
    LICENSE_MAX_SESSION = 0
    LICENSE_SESSIONS_WARNING = 0
    Picked latch-free SCN scheme 3
    Autotune of undo retention is turned on.
    IMODE=BR
    ILAT =121
    LICENSE_MAX_USERS = 0
    SYS auditing is disabled
    ksdpec: called for event 13740 prior to event group initialization
    Starting up ORACLE RDBMS Version: 10.2.0.1.0.
    System parameters with non-default values:
    processes = 1000
    sga_max_size = 3221225472
    shared_pool_size = 838860800
    java_pool_size = 117440512
    nls_language = AMERICAN
    control_files = /data1/oracledb/oradata/control/control01.ctl, /data1/oracledb/isddb/control/control02.ctl
    db_block_size = 8192
    db_cache_size = 1291845632
    db_keep_cache_size = 268435456
    compatible = 10.2.0.1.0
    log_archive_dest_1 = LOCATION=/data4/isddb/archive
    log_archive_dest_2 = LOCATION=/data5/isddb/archive
    log_archive_dest_state_1 = ENABLE
    log_archive_max_processes= 5
    log_archive_format = arch_%r_%t_%s.arc
    log_buffer = 14302720
    fast_start_mttr_target = 0
    undo_management = AUTO
    undo_tablespace = undotbs1
    undo_retention = 3000
    O7_DICTIONARY_ACCESSIBILITY= FALSE
    remote_login_passwordfile= EXCLUSIVE
    db_domain =
    instance_name = ISDDB
    service_names = ISDDB
    session_cached_cursors = 100
    job_queue_processes = 10
    cursor_sharing = similar
    background_dump_dest = /data1/oracledb/app/dumps/bdump
    user_dump_dest = /data1/oracledb/app/dumps/udump
    core_dump_dest = /data1/oracledb/app/dumps/cdump
    audit_trail = TRUE
    db_name = ISDDB
    open_cursors = 300
    os_authent_prefix =
    optimizer_mode = choose
    pga_aggregate_target = 629145600
    workarea_size_policy = auto
    PMON started with pid=2, OS id=368824
    PSP0 started with pid=3, OS id=549308
    MMAN started with pid=4, OS id=237724
    DBW0 started with pid=5, OS id=1810524
    LGWR started with pid=6, OS id=360824
    CKPT started with pid=7, OS id=1806348
    SMON started with pid=8, OS id=340460
    RECO started with pid=9, OS id=311604
    CJQ0 started with pid=10, OS id=450792
    MMON started with pid=11, OS id=553326
    MMNL started with pid=12, OS id=541124
    Oracle Data Guard is not available in this edition of Oracle.
    ALTER DATABASE MOUNT
    Mon Jul 5 17:02:15 2010
    Setting recovery target incarnation to 1
    Successful mount of redo thread 1, with mount id 1796698643
    Database mounted in Exclusive Mode
    Completed: ALTER DATABASE MOUNT
    Mon Jul 5 17:02:16 2010
    ALTER DATABASE OPEN
    Beginning crash recovery of 1 threads
    Started redo scan
    Completed redo scan
    1 redo blocks read, 0 data blocks need recovery
    Started redo application at
    Thread 1: logseq 26, block 2, scn 564335
    Recovery of Online Redo Log: Thread 1 Group 2 Seq 26 Reading mem 0
    Mem# 0 errs 0: /data1/oracledb/oradata/redo/redo02.log
    Completed redo application
    Completed crash recovery at
    Thread 1: logseq 26, block 3, scn 584337
    0 data blocks read, 0 data blocks written, 1 redo blocks read
    Thread 1 advanced to log sequence 27
    Thread 1 opened at log sequence 27
    Current log# 3 seq# 27 mem# 0: /data1/oracledb/oradata/redo/redo03.log
    Successful open of redo thread 1
    SMON: enabling cache recovery
    Errors in file /data1/oracledb/app/dumps/udump/isddb_ora_389510.trc:
    ORA-00704: bootstrap process failure
    ORA-39700: database must be opened with UPGRADE option
    Error 704 happened during db open, shutting down database
    USER: terminating instance due to error 704
    Instance terminated by USER, pid = 389510
    ORA-1092 signalled during: ALTER DATABASE OPEN...
    Which version was the 10.2.0.1 database before, and what were you doing in terms of upgrading to 10.2.0.1?
    Agreed.
    It looks like an incomplete upgrade scenario, this is consistent with having upgraded Oracle codeset but not having upgraded Oracle instance. Each individual instance has to be upgraded after upgrading Oracle codeset.
    If this is the case double-check Oracle upgrade README file for proper procedure.
    Jul 2010
    I have installed Oracle10G for the first time on IBM's AIX server
    i have created database manually.
    i got following error in
    startup.log:
    SQL*Plus: Release 10.2.0.1.0 - Production on Tue Jul 6 12:17:17 2010
    Copyright (c) 1982, 2005, Oracle. All rights reserved.
    SQL> Connected to an idle instance.
    SQL> ORACLE instance started.
    Total System Global Area 3221225472 bytes
    Fixed Size 2024344 bytes
    Variable Size 1644170344 bytes
    Database Buffers 1560281088 bytes
    Redo Buffers 14749696 bytes
    Database mounted.
    ORA-01092: ORACLE instance terminated. Disconnection forced
    and in alert.log file contains following error
    ARCH: Archival disabled due to shutdown: 1090
    Shutting down archive processes
    Archiving is disabled
    Archive process shutdown avoided: 0 active
    Tue Jul 6 12:09:33 2010
    IMODE=BR
    ILAT =121
    processes = 1000
    db_domain =
    audit_trail = TRUE
    db_name = ISDDB
    open_cursors = 300
    os_authent_prefix =
    PMON started with pid=2, OS id=471292
    PSP0 started with pid=3, OS id=237736
    MMAN started with pid=4, OS id=368654
    DBW0 started with pid=5, OS id=450680
    LGWR started with pid=6, OS id=1806486
    CKPT started with pid=7, OS id=573706
    SMON started with pid=8, OS id=569774
    RECO started with pid=9, OS id=282714
    CJQ0 started with pid=10, OS id=311434
    MMON started with pid=11, OS id=1798252
    MMNL started with pid=12, OS id=458882
    Tue Jul 6 12:09:34 2010
    Tue Jul 6 12:09:46 2010
    alter database mount
    Tue Jul 6 12:09:50 2010
    Successful mount of redo thread 1, with mount id 1796750602
    Completed: alter database mount
    Tue Jul 6 12:09:59 2010
    alter database open
    Started redo scan
    Completed redo scan
    Thread 1: logseq 28, block 2, scn 604343
    Recovery of Online Redo Log: Thread 1 Group 1 Seq 28 Reading mem 0
    Mem# 0 errs 0: /data1/oracledb/oradata/redo/redo01.log
    Thread 1: logseq 28, block 3, scn 624345
    Tue Jul 6 12:10:00 2010
    Thread 1 advanced to log sequence 29
    Thread 1 opened at log sequence 29
    Current log# 2 seq# 29 mem# 0: /data1/oracledb/oradata/redo/redo02.log
    Errors in file /data1/oracledb/app/dumps/udump/isddb_ora_242034.trc:
    Instance terminated by USER, pid = 242034
    ORA-1092 signalled during: alter database open...
    the error is quite clear - what dont you understand about it?
    do you actually have a database?
    Jul 2010
    I did install the Oracle10g
    and it showed successful installation but we have not done optional configuration settings.
    Later we executed netca and
    later we created the database but without creating the system01.dbf file.
    and it was done successfully
    I forgot to create the dbstart and pwd file previously so
    I created the dbstart and pwd file but after creation of the database.
    is it necessary to provide it with the system01.dbf file also?
    Mar 2006
    Charlotte, NC
    how did you created the database with out mandatory system table space? It seems you messed up. Better clean-up, read some oracle documentation then create the database again.
    Vijay Tummala
    Try hard to get what you like OR you will be forced to like what you get.
    Quote Originally Posted by aryaanu View Post
    ...later we created the database but without creating the system01.dbf file.
    Hard to believe - Check log harder.
    Jul 2006
    Try these steps
    Create a Database Manually
    Step 1: Decide on Your Instance's System Identifier (SID) The first step in creating the database is to determine the System Identifier (SID).
    This is what the environment will be set to when your database starts up
    and shuts down, and what the instance processes will have in their names as unique identifiers.
    My Instance name is called cat1020 you can use whatever you want. So
    wherever you see cat1020 replace with your name. Of course, use file system
    paths that are relavant to your machine.
    export ORACLE_SID=cat1020
    Step 2: Create the Initialization Parameter File (sample file below)
    $ cat $ORACLE_HOME/dbs/initcat1020.ora
    *.db_name='cat1020'
    *.DB_UNIQUE_NAME='cat1020'
    *.instance_name='cat1020'
    *.background_dump_dest='/rdbms/oracle_data/10.2.0/cat/bdump'
    *.compatible='10.2.0.1.0'
    *.control_files='/rdbms/oracle_data/10.2.0/cat/control01.ctl','/rdbms/oracle_dat
    a/10.2.0/cat/control02.ctl','/rdbms/oracle_data/10.2.0/cat/control03.ctl'
    *.core_dump_dest='/rdbms/oracle_data/10.2.0/cat/cdump'
    *.db_block_size=4096
    *.db_cache_size=30m
    *.db_domain='world.com'
    *.java_pool_size=31457280
    *.job_queue_processes=20
    *.large_pool_size= 8388608
    *.log_archive_dest='/rdbms/oracle_data/10.2.0/cat/arch'
    *.log_archive_format='arch%s%r%t.arc'
    *.max_dump_file_size='10000'
    *.nls_sort='binary'
    *.open_cursors=300
    *.pga_aggregate_target=100m
    *.processes=300
    *.remote_login_passwordfile='EXCLUSIVE'
    *.service_names='cat1020'
    *.sga_max_size=400m
    *.shared_pool_size=153431142
    *.undo_management='AUTO'
    *.undo_retention=10800
    *.undo_tablespace='UNDOTBS1'
    *.user_dump_dest='/rdbms/oracle_data/10.2.0/cat/udump'
    *.workarea_size_policy='auto
    Step 3: Connect to and Start the Instance
    Connect to the instance as SYSDBA either using operating system authentication or the password file method of authentication and start up the instance using the STARTUP command.
    >sqlplus '/ as sysdba'
    NOTE: If your parameter file is not in the default location or is not named init.ora, you may need to specify the PFILE clause in the STARTUP command for the instance to start. Because you do not yet have a database attached to the instance, you need to start up the instance in NOMOUNT state:
    SQL> startup nomount; The instance is now started and ready for the CREATE DATABASE command.
    # Change the numbers as you see fit for your environment.
    Step 4: Issue the CREATE DATABASE Statement
    create database cat1020
    user sys identified by sys
    user system identified by system
    logfile group 1 ('/rdbms/oracle_data/10.2.0/cat/redo01.log') size 5M,
    group 2 ('/rdbms/oracle_data/10.2.0/cat/redo02.log') size 5M,
    group 3 ('/rdbms/oracle_data/10.2.0/cat/redo03.log') size 5M
    MAXLOGFILES 5
    MAXLOGMEMBERS 5
    MAXLOGHISTORY 1
    MAXDATAFILES 100
    MAXINSTANCES 1
    CHARACTER SET US7ASCII
    NATIONAL CHARACTER SET AL16UTF16
    datafile '/rdbms/oracle_data/10.2.0/cat/system01.dbf' size 400M
    extent management local
    default temporary tablespace temp
    tempfile '/rdbms/oracle_data/10.2.0/cat/temp.dbf' size 25M
    undo tablespace undotbs1
    datafile '/rdbms/oracle_data/10.2.0/cat/undotbs.dbf'
    size 25M reuse autoextend on next 1M maxsize unlimited
    sysaux DATAFILE '/rdbms/oracle_data/10.2.0/cat/sysaux01.dbf' SIZE 500M;
    Step 5: Run Scripts to Build Data Dictionary Views
    @$ORACLE_HOME/rdbms/admin/catalog.sql
    @$ORACLE_HOME/rdbms/admin/catproc.sql
    REM * Alter SYS and SYSTEM users.
    REM *
    alter user sys identified by sys temporary tablespace temp;
    alter user system identified by system temporary tablespace temp;
    REM * For each DBA user, run DBA synonyms SQL script. Don't forget that EACH
    REM * DBA USER created in the future needs dba_syn.sql run from its account.
    REM *
    connect system/manager
    @$ORACLE_HOME/rdbms/admin/catdbsyn.sql
    @$ORACLE_HOME/sqlplus/admin/pupbld.sql
    Step 6: Create a Server Parameter File
    This step is optional, although highly recommended by Oracle. Your Oracle database was created by starting the instance with a parameter file, or PFILE. Because it is editable, you can migrate, easily, your new database to using a server parameter file. Creation of the server parameter file (or spfile) is accomplished by issuing the following statement:
    Create spfile from pfile;
    Good luck
    Jul 2010
    Thumbs up Thanks
    Thank you BeefStu
    your instructions was really helpful I am successfully able to create database and able to connect database.
    Previously my only problem was that I forgot to create the sys files
    Thank you
