    Jun 2009
    Gaps in Oracle Dataguard Standby
    Hello,
    The system is a Logical Standby Dataguard.
    With the following query it is possible to see that there are gaps:
    SQL> set numformat 99999999999
    SQL> set linesize 2000
    SQL> set pagesize 20000
    SQL> select thread# trd, sequence#,
    2 first_change#, next_change#,
    3 dict_begin beg, dict_end end,
    4 to_char(timestamp, 'DD-MON-YYYY HH24:MI:SS') timestamp,
    5 (case when l.next_change# < p.read_scn then 'YES'
    6 when l.first_change# < p.applied_scn then 'CURRENT'
    7 else 'NO' end) applied
    8 from dba_logstdby_log l, dba_logstdby_progress p
    9 order by thread#, first_change#;
    1 614 18542918309 18542918429 NO NO 04-DEC-2009 09:31:11 YES
    1 633 18543602669 18543836687 NO NO 04-DEC-2009 09:31:10 YES
    1 637 18543836687 18544028244 NO NO 04-DEC-2009 09:31:10 YES
    1 12832 203846572934 203846572944 NO NO 22-DEC-2009 09:31:10 YES
    Although all of them are APPLIED, and it is still receiving and applying the redo, it seems like there are some gaps.
    How can I check that the Standby is totally synchronized? How can I check if the Standby has still those archive logs that haven't been applied?
    Thanks in advance.
    May 2009
    check the system change number on primary and standby databases.
    Jun 2009
    Any other help please?
