Results 1 to 10 of 15
    Nov 2009
    India
    Question Help plz in sql loader!!!!
    I wan to use sql loader but when i am using it i get the following error
    sql*loader-501 unable to read file (dat file which i am using)
    sql*loader-563 bad length for var record
    can anyone plz help me
    thanks in advance
    bhu
    Mar 2006
    Charlotte, NC
    Post all control file parameters that you are using.
    Vijay Tummala
    Try hard to get what you like OR you will be forced to like what you get.
    Nov 2009
    India
    yup sure here is the control file
    load data
    infile 'c:/ex.dat' "var 3"
    into table exam
    fields terminated by ',' optionally by '"'
    (col1 char(5),col2 char(7))
    ex.dat file
    009hello,cd,
    010world,im,
    012my,name is,
    Mar 2006
    Charlotte, NC
    ex.dat file
    009hello,cd,
    010world,im,
    012my,name is,
    col1 is char(5) where as in the ex.dat it is more than 5. correct that.
    Vijay Tummala
    Nov 2009
    India
    ya i made the changes accoringly n here is my dat file
    hello,cd,
    world,im,
    012my,nameis,
    still i get the same error
    thanks
    bhu
    'hello','cd'
    'world','im'
    '012my','nameis'
    Nov 2009
    India
    ya i tried in the way u mentioned but still i am getting the same error...
    show it.
    post the whole session log.
    Nov 2009
    India
    here is the log file
    SQL*Loader: Release 9.0.1.1.1 - Production on Wed Nov 11 19:50:21 2009
    (c) Copyright 2001 Oracle Corporation. All rights reserved.
    Control File: C:\controlvar.CTL
    Data File: c:/ex.dat
    File processing option string: "var 3"
    Bad File: c:/ulcase5.bad
    Discard File: none specified
    (Allow all discards)
    Number to load: ALL
    Number to skip: 0
    Errors allowed: 50
    Bind array: 64 rows, maximum of 256000 bytes
    Continuation: none specified
    Path used: Conventional
    Table EXAM, loaded from every logical record.
    Insert option in effect for this table: INSERT
    Column Name Position Len Term Encl Datatype
    COL1 FIRST 5 , O(") CHARACTER
    COL2 NEXT 7 , O(") CHARACTER
    SQL*Loader-501: Unable to read file (c:/ex.dat)
    SQL*Loader-563: bad length for VAR record
    Lake Worth, FL
    Cool Remove the garbage
    Remove the "var" and the column lengths:
    -- Your control file
    load data
    infile 'C:\ex.dat'
    truncate into table exam
    fields terminated by ',' optionally enclosed by '"'
    (col1 char,col2 char)
    And you get this:
    H:\app\prj\sql>sqlldr scott/tiger control=ex.ctl
    SQL*Loader: Release 10.2.0.1.0 - Production on Wed Nov 11 09:18:47 2009
    Copyright (c) 1982, 2005, Oracle.  All rights reserved.
    Commit point reached - logical record count 3
    H:\app\prj\sql>type ex.log
    Control File:   ex.ctl
    Data File:      c:\ex.dat
      Bad File:     ex.bad
    Number to load: ALL
    Number to skip: 0
    Errors allowed: 50
    Insert option in effect for this table: TRUNCATE
    COL1                                FIRST     *   ,  O(") CHARACTER
    COL2                                 NEXT     *   ,  O(") CHARACTER
    Table EXAM:
      3 Rows successfully loaded.
      0 Rows not loaded due to data errors.
      0 Rows not loaded because all WHEN clauses were failed.
      0 Rows not loaded because all fields were null.
    Space allocated for bind array:                  33024 bytes(64 rows)
    Read   buffer bytes: 1048576
    Total logical records skipped:          0
    Total logical records read:             3
    Total logical records rejected:         0
    Total logical records discarded:        0
    Run began on Wed Nov 11 09:18:47 2009
    Run ended on Wed Nov 11 09:18:47 2009
    Elapsed time was:     00:00:00.37
    CPU time was:         00:00:00.11
    H:\app\prj\sql>
