    south africa
    procedure not compiling
    i am writing simple procedure but its erroring out due to alter
    this is on logical standby
    create or replace PROCEDURE pr_test
    as
      declare
        user       VARCHAR2(50 BYTE);
         adfg      VARCHAR2(50 BYTE);
       alter session disable guard;
    insert into AUDIT values (  user,adfg,sysdate);
    commit;
    alter session enable guard;
    end;
    end;
    it throws the following error
    SQL> show errors
    Errors for PROCEDURE PR_LOGACCESS:
    LINE/COL ERROR
    8/4      PLS-00103: Encountered the symbol "ALTER" when expecting one of
             the following:
             begin case declare exit for goto if loop mod null pragma
             raise return select update while with
             close current delete fetch lock insert open rollback
             savepoint set sql execute commit forall merge pipe
    any help is appreciated
    you are using sqlplus commands in plsql, cant do that unless you use execute immaediate
    south africa
    thank you ..appreciate your time
