    Dec 2003
    Mehamadabad
    Use Regular Expression to allow specific characters
    I want to put a validation on a column of a table. The column can have only following characters as a valid character.
    0-9, a-z, A-Z, $, *, +, ?, @, °, !, %, &, ', -, /, :, (, ), ., ,, #
    if any other characters are used an error is to be returned.
    I tried to use regular expression to solve the problem but i am new to it and not able to find a solution.
    Please help me out.
    Ramchandra Jetwani
    Check Constraint looks like the appropriate tool for this job.
    alter YOURTABLE
    add CONSTRAINT check_YOURCOLUMN
       CHECK (YOURCOLUMN IN ('0', '1', '2', ... '#'));
    Apr 2006
    The following is a regex version:
    SQL> create table check_reg (
      2     a1 varchar2(200)
      3     constraint a1_chk check
      4     (regexp_replace(a1, '[''0-9a-zA-Z$*+?@°!%&/:().,#-]') is null));
    Table created.
    SQL> insert into check_reg values ('_');
    ORA-02290: check constraint (TEST.A1_CHK) violated
    SQL> insert into check_reg values ('$');
    1 row created.
    SQL> insert into check_reg values ('ABCD456:)');
    1 row created.
    SQL> insert into check_reg values ('''');
    1 row created.
    SQL>
    SQL> select * from check_reg;
    A1
    ABCD456:)
    Dec 2003
    Mehamadabad
    Thank you very much. The suggestion solved my problem.
    Ramchandra Jetwani
