Results 1 to 8 of 8
    Aug 2009
    Need Help while running script encountered this error
    Hi everybody,
    I am running Oracle 10.2.0.1 database on linux Virtual machine. Running this script as given below, and encountered the problem of
    SQL> conn nzdint/nzdint@NZDefInt
    Connected.
    SQL> @ /home/oracle/Desktop/test.pdc
    ORA-06510: PL/SQL: unhandled user-defined exception
    ORA-06512: at
    "CTXSYS.CTX_DOC", line 1478
    exception
    ORA-06512: at "CTXSYS.DRVDISP", line 306
    ORA-06512: at "CTXSYS.CTX_DOC", line 1478
    ORA-06512: at
    ORA-06512: at line 9
    User-Defined Exception
    SCRIPT test.pdc
    set serveroutput on size 100000
    set pagesize 200
    declare
    -- Local variables here
    vbinaryContent BLOB;
    vTextContent CLOB;
    -- Test statements here
    dbms_lob.createtemporary(lob_loc => vTextContent,cache => TRUE);
    SELECT content INTO vBinaryContent FROM binary_table;
    ctxsys.ctx_doc.ifilter(data=>vBinaryContent,
    text=>vTextContent);
    INSERT INTO result_table VALUES(vTextContent);
    dbms_lob.freetemporary(vTextContent);
    EXCEPTION
    WHEN OTHERS THEN
    IF dbms_lob.istemporary(vTextContent) = 1 THEN
    END IF;
    dbms_output.put_line(dbms_utility.format_error_stack
    ||dbms_utility.format_error_backtrace
    ||SQLERRM(SQLCODE));
    end;
    IF SOMEBODY CAN WORK OUT WHAT's the PROBLEM AND GUIDE ME TO AVOID THIS PROBLEM, WILL BE a GREAT HELP.
    MACK_DBA
    looks like CTXSYS.CTX_DOC has raised a user defined exception which in not being handled by the code.
    Long term solution is to check the code and fix it.
    Exception may be caused by bad data, if that's the case fixing the data would be a nice workaround.
    Aug 2009
    Need Help : while running this script encountered this error
    Hi PAVB,
    Thanks for your response. However, the same script on another server is running without any problems. The another server I am mentioning , has the same configuraton. So, it is bit hard to accept your argument that "code needs to be fixed"
    Can you see any other reason, why the same code runs successfully on one machine and on another it shows this error?
    Look forward for somemore adivce from you.
    Mack_DBA
    Quote Originally Posted by Mack_DBA View Post
    Yes.
    Different data, data on one server raises an exception while data in the other server doesn't.
    Either way, code is not able to handle the raised user defined exception.
    The CTXSYS is probably lacking some basic grants.
    Look at dba_dependencies to see what is missing.
    Jun 2012
    Hello,
    we have the same error. Can you help us ?
    First you need to provide details one the error, perhaps show some sample code that you are running that shows that actual error stack for your problem. Second, this should be a separate post, as it is not related to whatever happened to the original poster.
    Jun 2012
    Thank you. I did a new thread already: see "Reload this Page Error with ctx_doc.ifilter under ORACLE 10.2.0.5". There are sample code and error message.
    I hope, it does help you.
Tags for this Thread
